Results 1 to 10 of 10
Thread: 2002 bmw 325xi burning oil
    Mar 2018
    Washington DC
    2002 BMW 325xi
    seems like my car is burning oil after a oil change. I really dont see any oil leaking just smoke coming from the engine sometimes. do any one know some of the things that may cause these problems?
    Apr 2015
    Netherlands
    2000 E46 328i
    CCV may need replacing, but keep in mind that the M54 engine consumes oil in any case.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I concur with Raddee. The temperatures are getting low in the DC area and cold weather aggravates a poorly functioning crankcase ventilation system (CCV). Changing the CCV is a pain in the butt job unless you’ve done it before. Find a reputable indie shop that specializes in bimmers at www.bimrs.org. I used to use J&F Motors in Shirlington (South Arlington) for major work on my bimmers. The shop has a great reputation and does quality work.
    Apr 2015
    Netherlands
    2000 E46 328i
    I've been told to test the CCV you can pull the dipstick while the engine is idling. You should notice a small difference in how the engine runs and sounds with the dipstick out and in. If there is no difference, your CCV is bad.
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by Raddee View Post
    You might have put the O-ring onto the filter cap too far and its leaking. The oil would run down the block and cause smoke once the car is warm.
    Gave away my BMWs, driving a VW and an Audi now.
    Jan 2016
    Ca
    2001 525it
    I would verify how much your actually using fill it write down mileage and date then when you need it again you have a reference point, check the ccv, also you could try lubimoly engine flush.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    You can do a rudimentary CCV check by removing the oil fill cap while the engine is running. There should be a slight vacuum.
    Lets say there is a slight vacuum at the cap. That likely means that the CCV is working. So I have to ask:
    - how many miles on the engine?
    - how many miles since the oil and filter were changed?
    - what brand and weight of oil was put in the engine?
    - were 8 quarts of oil put in the engine (“x” engines take 8 quarts)?
    - are you taking a lot of short trips (less than 10 miles)?
    - how is the car driven?
    - have you scanned the engine computer (DME) for codes?
    May 2017
    Palm Bay, FL
    2003 M3, 2001 330i
    Have you used any engine flush cleaners? These can cause old sediment to loosen and clog the oil ring on the piston forcing oil through the exhaust.
    Nov 2011
    nil
    nil
    What weight ans type of oil are you using? You might post the miles on the car. Has the car had maintenance like the CCV, ccv hoses, vac hose replacement, oil seals/dip stick housing cleaned out and replaced, oil cap seal replaced? Sometimes it's hard to see around that engine. The xi's are pretty tight in there. I know, we have a 330xi. You might get the car up on the ramps and remove the belly pans to look for leaks. Oil pan gaskets are a pretty common leak issue on these cars. I have to do ours next year.
    Regards
    Jun 2017
    Denver, CO
    325xi; 740i
    I feel oil consumption on the M54 is very engine dependent. Growing up my fathers E46 330xi would eat quite a bit of oil. Mine doesn't eat virtually any. I did my oil change 3 months ago and have put 5k miles (100 miles a day) on it since my oil change and even with a seeping oil pan my oil level is just a hair overfilled like I had it. When I did my oil change I put in 8 quarts (xi) and it was a quart overfilled so I popped the plug and drained a quart out and the level is now back in spec. (Mobil1 5w30) I also get bad gas mileage for 98% highway at 24mpg (fresh plugs and no codes) but that's also probably from me being liberal with the gas.
    New Daily:
    2011 Audi A6 Avant 3.0T prestige. 1 of 368
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    94' BMW 740i 308k miles
    Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
    Sold:
    1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
  1. FS: 2002 BMW 325xi EXC Condition, Pics/Video Inside
    By Smokem in forum BMW Cars For Sale / Wanted
    Last Post: 03-19-2007, 10:36 PM
  2. 1996 bmw 320iA burning oil
    By ncipps in forum 1991 - 1999 (E36)
    Last Post: 08-28-2006, 11:39 PM
  3. Audio Dilemma 2002 BMW 325xi
    By qwikdraw in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-11-2006, 09:12 PM
  4. 2002 BMW 325xi Car Alarm
    By qwikdraw in forum 1999 - 2006 (E46)
    Last Post: 06-05-2006, 11:24 PM
  5. Upgrading 2002 BMW 325xi Sound System
    Last Post: 06-05-2006, 11:22 PM
