Results 1 to 8 of 8
Thread: INPA help for 2008 X3
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Sob story here:
    https://www.bimmerforums.com/forum/s...er-replacement
    Short version is I have an INPA laptop I use for my E36 and E38. Those cars I use the OBDII cable with the round underhood adapter and it works great, but I can’t ready any codes on the X3. Will need to double check the error message, but IFH-009 or something rings a bell.
    Any help is welcome.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Philadelphia, PA
    2005 M3 & 2004 330i
    You need a D-CAN cable to read the engine module on the X3. And probably need to solder pins 7 and 8 to read any other module.
    Rutland, Vermont
    Here’s the cable I am using. I will spring for a known good one though.
    Philadelphia, PA
    2005 M3 & 2004 330i
    Is the cable in D-CAN mode?
    Rutland, Vermont
    There’s no switch on it. Is there a software method of changing mode?
    Also pins 7 and 8 do not appear the be jumpered but at this point just want to read engine codes anyway.
    Thanks!
    IL
    2000 740i sport
    Try using dcan tools to initiate the dcan cable setting after plugging the cable in...
    Sent from my SM-N960U using Tapatalk
    Rutland, Vermont
    Sadly running the dcan tool did not work. Maybe it's the cable. Thanks for the link and for sending the dcan software Purp.
    Feb 2019
    Broomfield
    2008 BMW X3 3.0si
    Quote Originally Posted by clarkitect View Post
    I just bought this same dcan cable. Were you able to get it to work?
  1. 2008 x3 misfire **strange problem** / Bmw techs please help!
    By bimmerman328 in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 01-11-2014, 08:14 PM
  2. I need your help for 2008 328i
    By tjwon2008 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-09-2008, 02:45 PM
  3. 2008 X3 Lost HD Radio Signal
    By TexasX3 in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 01-09-2008, 08:26 PM
  4. Help With BMW X3 2.5i 2004
    By littlestylish in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-15-2007, 09:51 PM
