Results 1 to 3 of 3
Thread: Re-Start Issues after water pump replacement
    Apr 2014
    Northville, MI
    08' E60, 01' E39it,99E39
    2001 E39 M54 525i Touring
    car has been sitting for over 12 months, inside garage, Michigan
    just replaced water pump belts ele vacuum valve and vacuum hoses, boots, disa.
    car now cranks but no start
    have fuel pressure
    any guess if sitting for so long have caused bore wash? ( if that is exactly what it is called; read it in Bentley, just can recall chapter/pg)
    I had a crank no start issue with our 99' e39 528i last summer and added 1 tsp oil to each cylinder etc and to my shock that car fired right up
    I hate to go through all of that if i missed and easier fix
    ps i carefully added coolant and let it bubble up the vent by resivor so i dont think i have any air in coolant sys.
    thanks in advance all
    Jan 2016
    Ca
    2001 525it
    We have had a few m54 e46's that had the wash down problem because the dme need to be reprogrammed. You had to push the gas pedal all the way down and keep cranking and eventually the engine would start. Maybe it just needs some more cranking.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Bad gas
  1. 96 Z3 won't start after water pump replacement
    By NMartin in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-11-2013, 02:21 PM
  2. Overheating After Water Pump Replaced
    By kcs in forum Convertible Questions
    Last Post: 04-08-2012, 11:37 AM
  3. Overheating After Water Pump Replacement
    By kcs in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-07-2012, 08:16 PM
  4. Burning coolant after water pump replacement
    By e38sd in forum 1995 - 2001 (E38)
    Last Post: 11-17-2010, 11:52 PM
  5. Issues during water pump replacement
    By raceyBMW in forum 1988 - 1996 (E34)
    Last Post: 01-25-2009, 07:21 PM
