Hello all I’m having a bit of an issue with my 5hp-30 I just swapped in a 2001 750il engine and trans into my 2000 E39touring and topped off the trans with new fluid and the issue I’m having is when I select reverse the trans will engage then disengage immediately and when I select drive it seems to slip a lot until I rev it up too about 3000 then it will thump kinda hard and go into failsafe 4th gear and reverse starts to work if I turn the engine off and on again same thing happens again
Cool swap - one I’ve thought about.... how was this drivetrain before? Is your battery healthy?
That sounds like it is low on transmission fluid - did you fill it correctly as specified here:
https://www.meeknet.co.uk/Gen_BMW/ZF...box.pdf#page=4
My BMW Repair YouTube Channel
Hello thanks for the url! I didn’t fill the trans quite exactly like in those instructions I believe I did fill it somewhat in that order I had it on a lift and used an electric pump to fill it with fluid while my brother shifted through the selections each time stoping for a bit and letting me fill it to the brim until it wouldn’t take anymore in any gear.
I hope you get it sorted. A V12 wagon would easily be a Jalopnik "build of the week" feature when completed.
if the fluid level is correct, voltage is correct, I would make sure the correct filter is being used. If all those check out. The valve body may need to be rebuilt.
I have no idea about your issue, but this is an awesome build. The triple x pipe I find especially cool. Is the car loud at all or what mufflers do you have on there?
Crazy thing is if you tried to put a V12 into a 740i everyone would say it’s impossible.
Nice build. Hope topping off the fluid does the trick.
Hello thank you for your reply I think I solved the problem I swapped transmissions with the previous obd1 M73 I had in the car and it shifts through the gears now! so I think I had a bad trans and thank god the older one was still good.
and now the only thing that seems to be left is I still have the transmission light on and I scanned it with inpa and the code that keeps appearing is (can brake signal) and internal status still says it’s in failsafe prog which I find wierd because it shifts through the gears? Haha but I will look over my wiring and see if I left something out. Maybe the E39 doesn’t have a module it needs idk haha any suggestions will be greatly appreciated thanks again
Haha Thank you! and I went with triple x pipe and single exit to smoothen the sound as much as possible. plus I’ve never seen it done haha and I’m glad I did it brings out the high pitch v12 sound nicely. which is hard with the m73 because it’s really raspy. but it’s not that loud haha. the x pipes and y pipes did bring down the level a bit. and with the unknown series 3 inch magnaflow at the end you can talk over it at idle.
Also just want to say the people in this forum are awesome I used to post in bimmerfest and there’s a lot les activity and help over there. It’s still a good forum but this one is much faster
