Results 1 to 19 of 19
Thread: E39touring M73tu (5hp-30 issues)
    Sep 2017
    California
    E39b54 e21b18 e39b25
    Hello all I’m having a bit of an issue with my 5hp-30 I just swapped in a 2001 750il engine and trans into my 2000 E39touring and topped off the trans with new fluid and the issue I’m having is when I select reverse the trans will engage then disengage immediately and when I select drive it seems to slip a lot until I rev it up too about 3000 then it will thump kinda hard and go into failsafe 4th gear and reverse starts to work if I turn the engine off and on again same thing happens again
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Cool swap - one I’ve thought about.... how was this drivetrain before? Is your battery healthy?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That sounds like it is low on transmission fluid - did you fill it correctly as specified here:
    https://www.meeknet.co.uk/Gen_BMW/ZF...box.pdf#page=4
    My BMW Repair YouTube Channel
    IL
    2000 740i sport
    Quote Originally Posted by Dark Phoenix View Post
    Pics of this swap please!
    Also make sure the fluid meets the LT71141 spec..
    Sent from my SM-N960U using Tapatalk
    Sep 2017
    California
    Quote Originally Posted by CPHES View Post
    Thank you! She started life as a 10/99 528iAT and yes battery sits at 12.6v engine off 11.2v cranking and 14.1v running thanks for replying
    Sep 2017
    California
    Quote Originally Posted by Timm View Post
    Hello thanks for the url! I didn’t fill the trans quite exactly like in those instructions I believe I did fill it somewhat in that order I had it on a lift and used an electric pump to fill it with fluid while my brother shifted through the selections each time stoping for a bit and letting me fill it to the brim until it wouldn’t take anymore in any gear.
    Sep 2017
    California
    Quote Originally Posted by purplecty View Post
    Yes of course haha I haven’t taken much but I have these
    And yes! I hope I have haha I’ve been using the redline d4 atf sold on ecs tuning for this trans.
    Jul 2016
    San Diego
    1998 E38 750iL
    I hope you get it sorted. A V12 wagon would easily be a Jalopnik "build of the week" feature when completed.
    Oct 2008
    Mclean, Va
    2000 Bmw 750il
    if the fluid level is correct, voltage is correct, I would make sure the correct filter is being used. If all those check out. The valve body may need to be rebuilt.
    Oct 2014
    Mesa AZ
    2000 740iL
    I have no idea about your issue, but this is an awesome build. The triple x pipe I find especially cool. Is the car loud at all or what mufflers do you have on there?
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Crazy thing is if you tried to put a V12 into a 740i everyone would say it’s impossible.
    Nice build. Hope topping off the fluid does the trick.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    Its important to observe the gearbox fluid temperature as well the actions you took. Topping off is best done at 30C - beyond 50C is not recommended as it would result in too little fluid, due to contraction, on cold start
    Sep 2017
    California
    Quote Originally Posted by Aitch View Post
    Hello Thank you very much that would awesome!!
    Sep 2017
    California
    Quote Originally Posted by 740il97g View Post
    Hello thank you for your reply I think I solved the problem I swapped transmissions with the previous obd1 M73 I had in the car and it shifts through the gears now! so I think I had a bad trans and thank god the older one was still good.
    and now the only thing that seems to be left is I still have the transmission light on and I scanned it with inpa and the code that keeps appearing is (can brake signal) and internal status still says it’s in failsafe prog which I find wierd because it shifts through the gears? Haha but I will look over my wiring and see if I left something out. Maybe the E39 doesn’t have a module it needs idk haha any suggestions will be greatly appreciated thanks again
    Sep 2017
    California
    Quote Originally Posted by KinkedChrome View Post
    Haha Thank you! and I went with triple x pipe and single exit to smoothen the sound as much as possible. plus I’ve never seen it done haha and I’m glad I did it brings out the high pitch v12 sound nicely. which is hard with the m73 because it’s really raspy. but it’s not that loud haha. the x pipes and y pipes did bring down the level a bit. and with the unknown series 3 inch magnaflow at the end you can talk over it at idle.
    Sep 2017
    California
    Quote Originally Posted by clarkitect View Post
    Hello how so? I’m curious haha
    Thank you!
    Sep 2017
    California
    Quote Originally Posted by chrisn7 View Post
    Yes I agree, I also tried that but unfortunately it didn’t work. but thankfully the new trans seems to have done the trick now I just need to figure out why i get the code(can brake signal) thank you for the reply
    Sep 2017
    California
    Also just want to say the people in this forum are awesome I used to post in bimmerfest and there’s a lot les activity and help over there. It’s still a good forum but this one is much faster
    Sep 2017
    California
  1. 5hp-30 transmission 540i 740i 750i
    By corrado413 in forum Drivetrain & Transmission Parts
    Last Post: 01-11-2012, 08:02 PM
  2. Is the 5hp 30 and 5hp 24 compatible?
    By Analog in forum 1995 - 2001 (E38)
    Last Post: 05-07-2009, 12:02 AM
  3. e38 ZF 5hp-30 (Non Steptronic) Automatic Transmission part number 24001422477
    By circfan2 in forum Drivetrain & Transmission Parts
    Last Post: 05-02-2009, 01:38 AM
  4. 5HP-30 Wiring Questions
    By noggins in forum 1995 - 2001 (E38)
    Last Post: 04-07-2008, 11:47 PM
  5. 5hp-30 auto tranny question for my 540i
    By bbarronson in forum 1988 - 1996 (E34)
    Last Post: 04-01-2008, 02:18 PM
