Results 1 to 8 of 8
Thread: Complicated no start
    Nov 2018
    Minnesota
    2000 323ci
    So I have a no start on my e46 323ci. Here’s what I can say:
    I just finished a m52tub28 swap on it, the engine was from a z3. I swapped the entire engine harness over including coil packs, but left all sensors as they were, except the crank position sensor, which was for sure working on the other car.
    i have yet to put the software for the 2.8 onto the dme, I wanted to test it it started on the 2.5 tune and then flash it to make sure ews didn’t get bunked from flashing it.
    it seems to have spark and fuel, as it will sputter, just not fully start.
    one injector is currently very leaky, but it still maintains fuel pressure.
    car was outside and some water did get in the electronics areas, but dme was not outside, and all fuses are still in tact after several start attempts, so I don’t believe that caused an issue.
    any information would be of use. At this point I’d believe it’s the flash file, but I don’t want to switch flash files and bunk the ews and then not be sure because it didn’t start regardless
    Nov 2018
    Minnesota
    2000 323ci
    Edit:
    sputters only when using starter fluid, so it should be sparking by that, however tested the injectors and it seems like they aren’t getting a signal, can’t seem to get them to open
    Nov 2018
    Minnesota
    2000 323ci
    Update:
    injextors have voltage, but can’t test pulse, don’t have the equipment. Would assume since there’s spark that there’s no pulse. Very very stumped. Any input would be appreciated.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The injectors have power as long as the ignition is in either the run or start position. The engine computer (DME) provides a ground to an injector when the injector is supposed to “fire.” Check for power at the injectors.
    Nov 2018
    Minnesota
    2000 323ci
    Quote Originally Posted by MarcoZandrini View Post
    I did check that, pulled the plugs back, they all have a 12V power, just nothing at the other pin.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    Any codes?
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Nov 2018
    Minnesota
    2000 323ci
    There’s like 10 codes that I can check later today / tomorrow, but nothing for fueling or ews, just some random vanos and throttle body codes
    Jun 2012
    New Mexico
    2003 328i
    Fresh motors can be cranky. Perhaps a few drops of oil down the spark plug holes would help. You may also have a piece of grit holding a valve off the seat.
    Sounds like it's ready to run unless you have some DTC's that say otherwise. Something may have been left unplugged.
  1. '97 328i M52 No Start - This one might be complicated
    By langstraad in forum 1991 - 1999 (E36)
    Last Post: 03-12-2014, 05:42 PM
  2. Complicated No Crank No Start issue!!!
    By purplecty in forum Diagnostic Software
    Last Post: 10-18-2012, 08:38 PM
  3. Newbe - starting prob bit complicated
    By peteb2428 in forum 1991 - 1999 (E36)
    Last Post: 10-10-2008, 12:44 PM
  4. Starting off!
    By MarkM5 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-01-2001, 12:45 AM
  5. Starting A Z3 Group
    By loug in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-26-2001, 06:47 PM
