Results 1 to 4 of 4
Thread: Non Return Valve 11611312737 direction
    Jun 2017
    Montreal, Qc Canada
    1991 M535i
    Hi guys,
    question regarding the round black and white non-return valve (or vacuum control valve) that is part of the emission system. It is located at the back of the engine bay, behind the intake manifold close to the firewall. #6 in the diagram.
    https://www.realoem.com/bmw/enUS/sho...diagId=11_2203
    There is a black side and a white side. Which way does it have to go on? Because it fits on both ways. But I'm sure it is directional. White side to the tube that goes to the intake manifold? Or other way around?
    Thanks guys.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Suck on it. The side that flows goes toward the intake manifold.
    Because, think about it, it's a vacuum control valve, a non return valve, that bleeds whatever into the intake manifold.
    Jun 2012
    New Mexico
    2003 328i
    I want to say the black end goes to the manifold. Try sucking on it. Whichever side allows vacuum through the valve goes toward the manifold. If you install it the other way it will be closed all the time and nothing downstream from the valve would function.
    Jun 2017
    Montreal, Qc Canada
    1991 M535i
    Got it! Black side towards the manifold.
    Thanks guys, as usual -> You Rock!
  1. Secondary Air Pump Non Return Valve
    By TIATO in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 01-20-2008, 10:45 AM
  2. Non-return valve where to buy 1 asap please
    By fstws6 in forum 1999 - 2006 (E46)
    Last Post: 11-23-2007, 10:37 AM
  3. Non return valve
    By uncle in forum 1991 - 1999 (E36)
    Last Post: 07-27-2007, 01:52 PM
  4. M60 intake manifold non-return valve
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 04-27-2007, 07:36 AM
  5. WTB: E34 brake booster non-return valve
    By bmwpower in forum 1996 - 2003 (E39)
    Last Post: 12-27-2005, 03:55 PM
