Results 1 to 6 of 6
Thread: Help: Shifter Neutral Side to Side
    Dallas, Texas
    1999 E36 M3 Coupe
    This morning I noticed that I can push the shifter like butter to the left while its in neutral, but when trying to push it to the right is feels rough as if its rubbing or catching on something. I have to apply much more pressure for it to go to the right from the center point. This is the low mileage E36 M3, it wasn't doing it a couple days ago.
    Thoughts?
    1988 - E30 M3 - Zinno/Black (45k)
    1990 - E30 M3 - Sterling/Black (S54)
    1991 - E30 M3 - Brilliant/Black (12k)
    1991 - E34 M5 - Black/Grey (90k)
    1999 - E36 M3 - Silver/Black (58k)
    1999 - E36 M3 - Cosmos/Black (15k)
    2018 - M760i - White/Ivory
    2018 - GTC4 Lusso T - White/Black
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    May need to do your transmission detent pins.
    Oct 2003
    Seattle
    99 M3
    Looks like transmission shift detent Pins
    http://www.m3forum.net/m3forum/showthread.php?t=398477
    https://www.bimmerworld.com/Drivelin...SABEgIj5_D_BwE
    What fluid are you running and how old is it? If you still have a positive ‘neutral’ position, then change the fluid to Red Line D4-ATF or MTL, or a mix of both, as a first step.
    Dallas, Texas
    1999 E36 M3 Coupe
    Car only has 15k miles so I can assume none of the fluids have been changed since 1999. I will do all the fluids to refresh, any other suggestions to get done to bring it up to speed while it’s at the shop?
    Jul 2005
    Indianapolis, USA
    1993 318i Touring
    Quote Originally Posted by TwinTurbo View Post
    Thoughts?
    I have a 1997 M3 that is just like this. Is this the way it is supposed to be? I thought there was supposed to be resistance there to prevent you from going easily into Reverse and 5th.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Correct. The shift detent pins and springs create that tension. If I'm not mistaken 5th and Reverse are the same detent and spring.
  1. Help!: Car leans to one side when parked
    By mattd in forum 1991 - 1999 (E36)
    Last Post: 09-04-2011, 01:34 AM
  2. HELP!!! Shifter neutral position offcenter!!!
    By sprtwin1 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-18-2006, 12:32 AM
  3. Searched but no help E36 listing to one side
    By wack in forum 1991 - 1999 (E36)
    Last Post: 10-08-2005, 02:19 AM
  4. HELP! tapping sound from both sides of engine.
    By abdoul in forum 1995 - 2001 (E38)
    Last Post: 07-14-2004, 04:24 PM
  5. help w/ wiring the left side park and tail lights
    By doreenerzz in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-20-2003, 11:30 PM
