RM European Auto Parts
Results 1 to 10 of 10
Thread: '16 328xi N20 in 13 528xi
    Oct 2018
    North LA
    f36
    Hello all, first post. Have been searching around and can not figure out how to find what I am looking for.
    We recently had an engine failure in our 2013 528 x-drive. We bought a complete engine out of a 16 328 xdrive, and it bolted right in, only having to re route a couple harnesses.
    The only issue is the front drive shaft seems a little short, which leads me to think the front differentials may be different either in some non-obvious dimension or the mounting holes.
    Does anyone know if the differential is different on the two cars? both n20 x-drive engines.
    The engines seem the same, but perhaps I am missing something.
    Thank you in advance for any input!!!!
    Dave
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I've just done some research at realoem.com for you.
    According to the information you gave:
    A 2013 528iX has an N20 engine.
    The front differential is part number ending in 520, and has a ratio of 3.23 to 1
    The oil pan has a part number ending in 638
    A 2016 328iX has an N26 engine.
    It has an oil pan part number ending 942
    It has a 3.15 to 1 ratio differential, part number ending 898 or 899.
    It certainly seems to me that you've bought entirely the wrong assembly for your car.
    Chris Powell
    BMWCCA 274412
    Oct 2018
    North LA
    f36
    Thank you Chris. yes, it's looking that way. its going to come back out to swap the pan and diff.
    Hopefully that will get it going.
    Jan 2016
    Ca
    2001 525it
    Better to check all all the info out be fore moving forward
    Oct 2018
    North LA
    f36
    Good Advice, will just have to muddle through it as I can not really find any references comparing the differences of the 2 N20 engines. It is going to be a mess for sure.
    If anyone that sees this does have a list of the differences of the N20 in the 3x-drive and the one in the 5x-drive, please post.
    I will be posting what we find after the job.
    Thank you all again.
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    i'd probably want to look at wiring diagrams and make sure something didn't change. just because the connectors match up doesn't mean wires are in the same place, 5v refs on same pins, etc....
    Jun 2002
    E39M5, E500 4WD
    I do not believe that an N26 is going to be happy connected to an N20 computer. While I do not know the differences, BMW doesn't generally rename engines without major changes.
    Which engine's turbo are you planning to use?
    Besides one engine being a SULEV, I see that the N26 has an electronic wastegate.
    Chris Powell
    BMWCCA 274412
    Oct 2018
    North LA
    f36
    Fortunately Both engines are N20B20A - working on going over them part by part now and will follow up.
    Thank you all for your help!.
    Jun 2002
    E39M5, E500 4WD
    I'm not saying that realoem.com is always right, but I do not see an N20 being available in 2016 in a 328iX:
    https://www.realoem.com/bmw/enUS/sel...&prod=20150900
    IF it's actually an N20, I don't see a reason for the fitment issues you have found.
    Chris Powell
    BMWCCA 274412
    Oct 2018
    North LA
    f36
    Well, the engine I bought was an N20B20A out of a California 2016 328xi, 15k miles. The engine in the 13 528 was also a N20B20A as marked on the front of both blocks.
    The car it went in, which is NOW running and driving, is a 2013 528xi.
    To make it work I had to move the following from the old 528 engine to the new 328 version:
    Installed 528 Oil Pan
    Installed 528 Front Differential
    Installed 528 vacuum waste gate instead of the electronic waste gate on 328 engine.
    Installed 528 vacuum pump, as it has an extra port for the wastegate.
    Installed 528 engine harness.
    Installed 528 Engine Mounts.
    and of course used the original 528 ECU
    Car started right up, no codes, all operations normal, runs great!
    Entire project $3165.62 + plus my labor and frustration.
    Thank you all for your help, I hope this thread assists someone in the future.
    Will be parting out old engine and the 328 n20 parts I did not use.
    Dave
  1. TechFest East '04 May 13-16, 2004
    By 1996 328ti in forum Middle Atlantic - US
    Last Post: 05-08-2004, 08:56 PM
  2. TechFest East May 13-16, 2004 Washington, DC area
    By 1996 328ti in forum New York / New Jersey / Connecticut
    Last Post: 04-25-2004, 12:41 PM
  3. TechFest West in SoCal, March 13-16
    By scottn2retro in forum California sponsored by Avus Autosport
    Last Post: 02-12-2003, 07:28 PM
