Results 1 to 24 of 24
Thread: Vibration under low speeds 2003 330i
    Sep 2018
    New York
    2003 330i
    Ok so I had a bad center support bearing that was causing a really bad vibration. I went along and changed the guibo and the center support bearing. This fixed most of the vibration but I still notice a slight vibration when cruising around the city, I know my driveshaft is still balanced because I took it to a shop to get checked and they told me everything is fine. Pls help. I’m not sure if this relates in anyway but I also have a shaking issue when trying to slow down from high speeds I’m thinking there’s something wrong with my brakes. Any advice would be amazing. Ps the vibration at low speeds is not a crazy strong vibration, just slight.
    Jun 2012
    New Mexico
    2003 328i
    Driveline out of alignment due to bad engine or trans mounts, centering sleeve in the guibo end of the driveshaft, improper preload on the CSB or bad universal joints are all possibilities.
    A bad CSB can harm old and crusty universal joints. When the driveline is flopping around under there it generates abnormally high loads and much higher deflection than normal. It can basically kill your driveshaft.
    Sep 2018
    New York
    2003 330i
    I have new engine mounts I just haven’t put them in yet, ima get to that this weekend hopefully.
    Sep 2018
    New York
    2003 330i
    The specialist at the driveshaft place also told me my u joint was fine in my driveshaft
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Did the tech check out the center support bearing?
    Sep 2018
    New York
    2003 330i
    yeah the center support bearing was changed a few days prior.
    Dec 2013
    Chicagoland area
    EXOTICS
    The symptoms when slowing down indicate it may be:
    • A suspension component, most likely(FCAB's)front control arm bushings.
    • If vibration felt mostly through the steering wheel, then it may be front brake rotor deposits or warping.
    Sep 2018
    New York
    2003 330i
    I just changed the front control arm bushings about 200 miles ago
    Dec 2013
    Chicagoland area
    EXOTICS
    Was a proper wheel alignment performed after the suspension components were replaced?
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Lots of people have tried to change out the CSB on Audis, for example. It's so tough to do right that audi normally won't even sell you one...you have to get a complete driveshaft assembly including new CSB AND CSB mount! You DID change the CSB mount?
    But I'm sure you did it right. Right?
    Sep 2018
    New York
    2003 330i
    Yes I changed everything the only thing I could not change was the centering sleeve because I couldn’t find a tool online, I haven’t gotten the car aligned yet because I’m going to get a new set of tires in the next week.
    Sep 2018
    New York
    2003 330i
    I’m about 60% sure my engine mounts are going bad, I read somewhere if you feel some vibration in the steering wheel it’s an indicator of the mounts going bad, can anyone confirm this?
    Nov 2018
    Elon, NC
    E46 330i
    You might also want to check your control arms and calipers (sticky calipers can cause vibrations). Bent or unbalanced wheels are another possible source of vibrations.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Quote Originally Posted by E46jaime View Post
    I"m sure you did read it somewhere. That doesn't mean it's right or that I would agree with it. Vibration in steering wheel while going down the road is almost certainly wheel balance, wheel out of round or bent, bad tire or flat spotted tire (happens!), less often loose tie rod ends, etc. Engine mounts are generally an idle issue. High mileage could also be a guibo issue. Cracks in the guibo usually mean time to replace...those cracks get bigger every time you accelerate or decelerate in gear.
    Sep 2018
    New York
    2003 330i
    Yeah I’m thinking im going to change my front rotors and pads, is it wrong for me to just change the front rotors and not the rear
    Nov 2018
    Elon, NC
    E46 330i
    As long as you do them in pairs, it's OK to replace only front or only rear.
    Dec 2013
    Chicagoland area
    EXOTICS
    You'll be fine, have you checked the rotors for deposits?
    Nov 2018
    Szczecin
    BMW M3
    Are you sure that it's the front shields?
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    That centering sleeve was critical on Audi driveshafts. But then audi shafts came with a complete new center bearing mount/sleeve.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Yes you can change them in axle sets. However, 99% of the time vibration isn't due to bad rotors...deposits on rotors generally the issue. FWIW I've not had problems with BMW rotors using BMW (textar) pads. YMMV. But stoptech's bedding procedure solves most rotor/pad problems. Don't change the rotors unless they're worn below factory limits.
    Jan 2017
    USA
    E21, E46
    Typically low speed vibration is due to any of the following:
    Flex disc worn
    Center bearing issues
    Driveshaft mounts
    Universal joint issues
    Incorrect alignment
    Sep 2018
    New York
    2003 330i
    I haven’t checked the rotors for deposits yet, the reason I’m starting to think it’s my front brakes is because I had a really badly warn control arm bushing maybe a month and a half ago and that was causing some serious vibration. Maybe that messed up my front brakes idk I might be on a wrong suspect. What do u guys think
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Check the rear axles for torsional play.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    control arm bushing nothing to do with brakes.
    brakes is brakes. generally you get vibration when using them if there's an issue...otherwise it's wheels, tires, front balljoints (integral with front arms on BMW e46 and especially m3).
  1. Groaning noise under low-speed right turns
    By Substream in forum 1991 - 1999 (E36)
    Last Post: 12-25-2008, 05:11 PM
  2. Replies: 14
    Last Post: 09-18-2008, 10:27 PM
  3. Engine stalls under low speed braking
    By Alpinewhite 633 in forum 1976 - 1989 (E24)
    Last Post: 09-17-2008, 09:53 PM
  4. Replies: 1
    Last Post: 02-21-2008, 05:36 PM
  5. Vibration at low speeds
    By skanders in forum 1991 - 1999 (E36)
    Last Post: 11-04-2007, 12:39 PM
