Results 1 to 8 of 8
Thread: Hot Wiring The Horn
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Hot Wiring The Horn
    Hi all, 1995 525i 5 SPD 281k
    My car is up for inspection this month. I replaced the steering wheel but, haven't purchased the part that touches the metal part of the steering wheel for the horn. Is there a way to hot wire the horn so that when the inspector asks me to press the horn, all I have to do is touch two wires? I believe I have to wire the part because they don't make a plug-in part for my model, in which I will do in time but, for now, I would like to find out which wires I need to touch together to set off the horn.
    Thanks in advance.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Thank you sensei...
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by drewusmaximus View Post
    Thanks in advance.
    Please, at least rig a button for this in case you actually need to use it.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by ross1 View Post
    Do you mean a toggle switch? I can do that... Thanks for the idea.. Just ordered one...
    Sep 2001
    Sharon CT
    you dont have a local mechanic that will just throw a sticker on it ? as long as everything else is up to snuff safety wise i would imagine it wouldnt be a problem.
    Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
    88 Alpineweiss / black E30 M3 -Project.
    Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
    98.5 Tiag Silber /black e36 m3 - Modded.
    99.5 Estoril Blau /dove e36 m3 - Modded.
    07 Crimsonrot /black E83 X3 6spd - Stock..
    moroza's Avatar
    BFE
    E34T
    I was disqualified from a CA driving test because my horn didn't work. It's officially a safety item.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by Neel View Post
    The guy I bring it to is very lenient. I had an 18 inch vertical crack on my windshield last inspection and he passed it. In New York State the maximum allowable crack is 11 inches. He doesn't pull off the wheel to check the brakes and doesn't look for tire wear.
    I don't like taking advantage. The least I can do it make sure the horn is functional. I don't think I have to pull off the steering wheel. I can just pop off the column covers and splice in the toggle switch. Then when the carbon pin comes in, I can adjust correctly for a permanent solution. I just need to figure out which wires are for the horn, since there are four wires that connect to a connector. I used to have the clock spring with the grey ribbon so, I need to trace the horn wires to splice in the toggle switch, or at the very least, make sure I can touch them together to activate the horn during inspection.
  1. Can I "hot wire" my bmw???
    By BMWFAN in forum 1991 - 1999 (E36)
    Last Post: 01-03-2021, 09:09 PM
  2. hot film MAF vs. hot wire MAF???
    By 2nd II None in forum 1988 - 1996 (E34)
    Last Post: 06-16-2007, 06:17 PM
  3. Hot wire MAF vs. Hot flm MAF???
    By 2nd II None in forum 1991 - 1999 (E36)
    Last Post: 06-16-2007, 05:47 PM
  4. Angel Eye hot wire?
    By fastfly in forum 1991 - 1999 (E36)
    Last Post: 02-19-2005, 07:04 PM
  5. Hot wire in sunroof pannel??
    By Bham BMW M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 07-03-2003, 02:53 PM
