Results 1 to 14 of 14
Thread: Headlight Bucket Low...
    Mar 2010
    Vancouver, BC
    1990 BMW 850i, 1976 Nova
    now in Standard time its dark after work and need light... my driver side headlight looked low so i used a Phillips screw driver to spin the adjuster and raise it up but it only goes so much and stops, as if its stripped.
    is it stripped or is there another underlying issue?
    gotta raise it up, need more light higher...
    "...i haven't taken leave of my senses Bob, I've come to them..." -- Ebenezer Scrooge
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    The adjuster wheel is either disconnected from the adjusting slide, or it is missing completely. Make sure you have all three connected and working properly, as they work together - if one fails, then the light just wobbles around.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Mar 2010
    Vancouver, BC
    Quote Originally Posted by TxGR8White View Post
    the light goes down if i turn it that way, but only upwards so far... but i will look down inside to see if i can find the connections...
    thanks!
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    If you put your thumbs on the lense with your fingers on the housing, does the lender move about? If so, your adjusters are broken.
    Mar 2010
    Vancouver, BC
    Quote Originally Posted by cartoonz View Post
    lens in ok.... what is an adjusting slide?C922A3F8-C9C6-40BE-9C5B-3479B7DE5B2C.jpeg
    Actually when I spin the adjusting wheel in the same direction , eventually the headlight changes direction..,
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's not the right thing to be twiddling - those are only needed to raise and close the pop-up function of the headlights if the motor fails. The adjusters are actually on the headlight assembly - quite where I'm not sure as I only have experience of the Euro lights....
    My BMW Repair YouTube Channel
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    His car has the Euro lights (J-spec) 8-)
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Ahh! Info here:
    Mar 2010
    Vancouver, BC
    Ahh! Info here:
    awesome... thank you very much Timm,,, you too Wuffer...
    Dec 2007
    Dallas, TX
    Quote Originally Posted by Wuffer View Post
    One of the three adjusters is broken - tabs that "lock" it in broke, so it won't adjust correctly.
    May 2018
    london, uk
    1995 840 CI auto
    Crosspost from the uk forum...
    My MOT is coming up, I've replaced the NS pod with a used one that still has working adjusters, BUT they need adjusting for the MOT to bring the focus high enough..... (raising) and I'm terrified to touch the adjusters for fear of brittle aged plastic explosion.
    Does anyone have any good tips on adjusting them without exploding the plastic adjusters? soak them with wd40 first? heat the plastic with a hairdryer to make them less brittle? All mad but "it might just work" suggestions welcome before I explode these adjusters! >.<
    Cheers, would really like to avoid having to break and replace them for the sake of the MOT when they are so close to being fine! (but not quite fine enough to pass the mot)
    Dec 2007
    Dallas, TX
    Have you tried using the adjustment in the car? The thumb wheel on the right side of the instrument cluster where you can drive the lights up or down - it might be enough to get them into the proper position.
    May 2018
    london, uk
    1995 840 CI auto
    Thanks Tx,
    Yes, it's that the new lamp doesn't line up with the exisiting one which is at the correct height, so I will definetly have to adjust it...
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The headlights do adjust reasonably easy - just as long as you don't put undue pressure on the adjusters you should have no problem - here's the routine:
    https://www.meeknet.co.uk/E31/timms_...adjustment.htm
    ...and if you break them:
    http://www.meeknet.co.uk/e31/bmw-e31...ter-repair.htm
  1. Need to replace Headlight buckets
    By PbFut in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-31-2006, 12:08 PM
  2. E30 & E34 headlight buckets, same size?
    By 2DYE4 in forum 1988 - 1996 (E34)
    Last Post: 08-21-2006, 12:03 PM
  3. Ram-Air Headlight Bucket?
    By Holeshot in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-02-2006, 12:26 PM
  4. Headlight issue? Low beam failure
    By M3andPorsche in forum 1992 - 1999 M3 (E36)
    Last Post: 11-11-2005, 12:10 PM
  5. headlight buckets
    By mufdyvr002 in forum 2002
    Last Post: 11-06-2005, 09:29 PM
