Results 1 to 25 of 25
Thread: Sound deadening removam
    Oct 2016
    PNW
    E36 M3 Coupe
    So I’ve been working on ripping out the sound deadening in my car for 2 or 3 days now after work. I had luck with getting it all removed from the rear but am having a difficult time getting it out from under the seats. Is there something I can put on it to loosen up the adhesive? I feel like I’m gonna break my pry bar.
    Also, is there something you guys are using to clean all the adhesive off the body? I’ve been using acetone which is working but with a ton of effort. Any help would be appreciated!
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    Heat it with a heat gun and scrape it off in big chunks. Then use xylene to wipe off the residue. You'll want plenty of ventilation.
    A house
    '86 325e, '14 VW EPA
    Apr 2018
    Salt Lake City
    E91 Daily, E46 Race Car
    Heat gun and a plastic scraper then an industrial adhesive remover for the residue
    Aug 2012
    Central, MD
    1995 M3
    Yep heat gun and scraper. Then believe it or not, try spraying WD40 on the residue, cleans right off.
    socal
    330i, 323i
    do not waste time with dry ice.
    '93 e36. Heat gun ftw
    none
    Oct 2016
    PNW
    E36 M3 Coupe
    Dope thanks guys. Guess I’m getting a heat gun
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    Has anyone ever tried to use an oscillating tool?
    Aug 2012
    Central, MD
    1995 M3
    Just watching that vid, it leaves a lot of residue behind. A heat gun oddly doesn't. It feels like the heat gun releases the adhesive underneath.
    May 2015
    Easton, PA
    1996 BMW 328is
    I used a pneumatic air chisel....at least until I made about 3 more holes in the floor pan, which I then needed to fix
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    I used a heat gun and a putty knife. Mineral spirits to remove the remaining adhesive residue. Mineral spirits didn't seem to be as hard on the paint as something like acetone.
    Aug 2012
    Central, MD
    1995 M3
    Double-U-Dee-Forty. Seriously.
    Aug 2012
    Central, MD
    1995 M3
    Oct 2016
    PNW
    E36 M3 Coupe
    Quote Originally Posted by aeronaut View Post
    Holy crap! I’m using the wd40 when I get home. Bought a heat gun and used paint thinner last night. Better but still a pain in the ass
    Aug 2012
    Central, MD
    1995 M3
    The off-brand stuff works too. I had a couple cans of Walmart "super tech" lubricant spray. Work just as well.
    Marietta, GA
    95 M3, 87 535is
    +1 for heat gun. I've tried the dry ice technique. It works but its more expensive and more time consuming. Heat gun works way better.
    Oct 2016
    PNW
    E36 M3 Coupe
    Tried the wd40 tonight but the paint thinner worked better
    Sep 2013
    Perth, Australia
    2011 BMW 135i
    I did mine in the middle of Australian summer in a hot warehouse and it just lifted out.
    Otherwise heat gun and plastic scraper.
    There was only a little residue left which I removed with brake cleaner, it was the only thing I had handy and it worked.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by Wastatepride View Post
    I would expect it might, but WD easier to deal with for me.
    Montreal, Quebec, Canada
    E46 330 ZHP, E36 328i
    If it's not too late refrain from walking directly on the material (With carpet removed).
    It makes it very hard to remove after. I don't understand the concept but I sure noticed it...
    oskaloosa,ia
    '01 3.0 ZCoupe
    I used a combination of dry ice and the heat gun. dry ice worked great, and left no residue. Heat gun is actually faster, but leaves a residue. Wiped it down with a gas soaked rag, and it cleaned up well though.
    Irwin, Pa
    97 M3, 12 135i
    For the residue, mineral spirits works great.
    Nov 2005
    Alpharetta, GA
    '95 M3 IP #595, '07 Z4MC
    This time of year, you can also be opportunistic and use cold weather. When I did mine years ago, I rolled it out of the garage and left it out during a 25 degree night. In the morning it all chipped up like peanut brittle. No residue either.
    FL
    are slow.
    Quote Originally Posted by Michael9218 View Post
    This.
    Really depends on the consistency of the sound deadening however. On my E30, after a sub-freezing night, it chipped right off the next morning in nice sized pieces. On my Mustang, and on the E36's I've done this on, the heat gun seemed to do the trick quite well. I prefer WD-40 over mineral spirits as well. The heat gun makes enough stink from melting the tar, you don't need anymore.
    Also, don't buy the Harbor Freight heat gun. It melts itself to death, and while doing so it absolutely stinks like burning plastic. Go buy the Milwaukee heat gun from Home Depot or similar from Amazon. Money well spent.
    -Dr. Seuss
    Jan 2019
    Connecticut
    E92, E46, E36
    I had the best luck with a heat gun lightly warming if on my e36
  1. Effective sound-deadening experiences?
    By infocalypse in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-30-2012, 10:58 AM
  2. Sound Deadening 96 M3
    By ///|V|3 BRAD in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-19-2003, 10:47 AM
  3. Got rid of sound deadening crap + airbox question
    By DiScoTeknix in forum 1991 - 1999 (E36)
    Last Post: 09-04-2002, 11:06 PM
  4. Any negatives to removing engine sound deadening material?
    By JoeZ in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-13-2002, 09:36 AM
  5. Removing Sound Deadening Material
    By Hyperion in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-27-2002, 12:32 PM
