Results 1 to 7 of 7
Thread: Coolant consumption
    Jul 2018
    Washington
    99 e46
    Coolant consumption
    I have a 99 328i sedan and I replaced the upper and lower hoses along with the sensor and the expansion tank, and I've still got some sort or coolant consumption or leak. I've pressure tested it and havent found anything. I dont think there is a leak and it's not my head gasket. My secondary airpump is however throwing a code, any ideas?
    Jan 2017
    USA
    E21, E46
    Coolant consumption
    If you drop pressure on the coolant pressure leak test however no visible leaks then perform a compression / leakdown cylinder test.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The cooling system in the E46 demands that it be properly bled. Go to E46Fanatics and check out a sticky in the cooling system that was written by Mango. You likely have air in the cooling system.
    Apr 2015
    Netherlands
    2000 E46 328i
    The cap on the expansion tank is prone to leaks. Easy replacement to try.. Get an OEM one, though.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Quote Originally Posted by Minimule77 View Post
    You might want tø google or research secondary air pump overhaul or repair on an audi. I've owned audis since 2000 model year and have seen lots of secondary air pump (and those damned combi valve failures...even had a couple of those!) failures online but fortunate not to have one.
    Jul 2018
    Washington
    99 e46
    I replaced the cap when I replaced everything else, I bled it too, you think the consumption could be due to air in the system? I also plan on replacing the air pump.
    Oct 2003
    Seattle
    99 M3
    Coolant consumption
    Yes, air in the system can present as a leak as the air is forced out of the system, though you may want to accomplish a compression leak down test.
    Generally, with a SAP failure, it was a failing SAP valve that allowed exhaust gasses into the pump bearings. If you have a failed pump, it is best to replace the valve.
  1. Oil and coolant consumption
    By csheen1234 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-11-2015, 07:12 PM
  2. BMW M50 coolant consumption
    By Resumane in forum 1988 - 1996 (E34)
    Last Post: 02-12-2013, 10:26 PM
  3. Coolant consumption (!!!) or air pocket?
    By penguinc00 in forum 1996 - 2003 (E39)
    Last Post: 01-17-2012, 11:42 PM
  4. Coolant consumption
    By nuhockeyfan in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-25-2008, 11:51 AM
  5. Coolant consumption e32
    By acwbart in forum 1988 - 1994 (E32)
    Last Post: 09-24-2007, 10:47 PM
