Imola Red exterior- specific ZHP e46 sedan color- WBAEV53463KM05160, clean Title in my name.
Black interior- heated Nappa leather M6 seats with electric adjustable lumbar and side bolsters seats.
VF Supercharger extremely smooth power, see DYNO chart, no dips in power, no spikes, just smooth increase power and torque
Current mileage 195720 as of 11/01/18
Original Engine replaced at 172250 miles, replacement engine from 2004 330ci automatic convertible, vin WBABW53454PL45828, mileage when car was salvaged 108,958. Engine in great condition. so current engine has 132428 miles. I have the Carfax verifying mileage of engine.
Engine was purchased on 5/7/2015 from Quarry Motors in Naples Florida and shipped to me. See the pictures of the engine when I received it. The engine was spotless clean. upon opening the valve cover, the internals were also very clean.
The engine swap and all preventive maintenance items was done around Nov 8 2015. Took about 1 week to complete do all the maintenance and cam swap...
Almost everything engine related was replaced during the engine swap. Below are the items replaced.
1. Swapped over the ZHP cams
2. Install Vanos Beisan kit
3. install catless headers
4. new exhaust gaskets
5. install 2- Vibrant 200 CEL high flow race catalytic convertors in section 2
6. new valve cover gasket
7. new oil pan gasket
8. new 2nd air pump filter
9. oil pump nut safety wired
10. new coolant temp sensor
11. new front and side cam position sensors
12. new water pump
13. new throttle body o ring
14. new thermostat
15. new radiator
16. new coolant tank
17. new coolant tank cap
18. new- ALL coolant hoses including the hard-plastic lines under intake manifold
19. new intake manifold gaskets
20. new knock sensors
21. new OFHG
22. new serpentine belt
23. new idle pulley
24. new cabin air filter
25. new Mass Air Flow meter
Since I have owned this ZHP, I have replaced the following parts:
1. New M3 motor mounts
2. UUC transmission mounts
3. New Guibo
4. New Center Support Bearing
5. New Rear driveshaft CV joint
6. New Right Half Shaft CV boots
7. New AKG front control arm bushings
8. New AKG Rear trailing arm bushings
9. New AKG rear subframe bushings
10. New AKG rear differential bushings
11. New Windshield
12. New Windshield cowl screen
13. New Power steering pump
14. New Clutch slave cylinder
15. New fuel filter
16. New Bosch fuel pump
17. New Sunroof shade clips
18. New headlight lens
19. New front and rear brake pads
20. New front brake rotors
21. New Left front wheel bearing
22. New all 6 Bosch fuel injectors
23. New all 6 Bosch coil packs
24. NGK Iridium spark plugs (1 range colder)
25. New BMW ZHP shift knob
26. Full size 18" spare wheel/tire
The following performance upgrades were installed:
1. VF engineering- Vortech V2 Supercharger kit- Dyno in 2015- 283 RWHP, approx 315 at crank.
2. German Auto Solutions- DISA valve upgraded kit with O-Ring
3. UUC under drive pullies
4. Catless headers
5. Syndro Design Works- Single mass lightweight Flywheel and clutch
6. BMW factory Short shift kit with cartridge bearing and Derin bushings
7. Exhaust resonators deleted with Vibrant 200 CEL race catalytic convertors
8. Active Autoworks rear muffler
9. M3 fuel tank baffle
10. Brembo GT front big brake kit- 4 pistons calipers
11. Front brake dust shield removed for better cooling
12. Stainless steel brake lines
13. E90 335i rear brake calipers, pads, stainless steel lines (25% bigger pad and piston)
14. Bilstein PSS9 9-way adjustable coil over suspension
15. H&R front and rear sway bars
16. Rear adjustable control arms
17. E46m3 front top strut mounts
18. Active Auto Works front strut brace.
19. Front strut reinforcement plates
20. Welded rear subframe chassis reinforcement
21. 3.38 open differential
22. Euro traction control coded
23. Crank Case ventilation deleted- Moroso Oil Catch Can installed
24. M6 electric heated, adjustable lumbar and side bolsters front seats
25. SSR competition 18x8 wheels
26. Bridgestone RE71 255-35-18 tires
27. Front hub stud kit
28. Clutch delay valve removed
The following aesthetics upgrades were installed:
1. LED angel eyes
2. Xenon fog lights
3. Xenon headlights FX upgrade
4. LED rear taillights
5. 3M carbon film roof and rear bumper diffuser wrap
6. 30% window tint
7. Interior mirror with compass, garage door opener, automatic dim
8. Electric power folding M3 mirrors- hydro dip carbon fiber, mirror switch, coded to fold with key
9. European M3 driver mirror dual section lens.
10. Colby Alcantara steering wheel and shifter surround
11. Airbag recall done
12. Bose subwoofer inside spare wheel- amp in the trunk
13. BMW M pedal sets- Gas, Brake and Clutch
14. BMW M Dead pedal
Other information:
ZHP passed emission after a retune in Oct 2018. It failed in 2017 because original Supercharger injectors were leaking causing check engine light. This was fixed with new Bosch EV1 injectors and TRM retune to match these injectors. Car gets 27MPG at 75 mph highway.
ZHP is my backup track car so it has been used on track 12 times. After each track event, it gets new oil and filter changes.
Mobil 1 European car formula 0W40 engine oil
Redline transmission and differential oil
BMW blue coolant with distilled water and water wetter added
Car was dynos with 283HP at the rear wheel. Approx. 310 crank HP
VERY SMOOTH power and torque curves. No dips as the revs build. See dyno chart
AC blows ice cold- 38 deg at center vent on max cold. See picture, Heat is HOT
2 master keys- both coded to lock, unlock doors, trunk, open and close sunroof and windows, fold unfold mirrors
Added rear seat center pass thru if you need to haul long objects.
Headliner in excellent condition- no sagging
Cons:
A, B, C pillar fabric peeling- common e46 issue
Headlight self-leveling does not work because left headlight housing is a halogen light housing due to supercharge intake tube requirement
Both left and right quarter panel edge has metal and paint damage from previous owner trying to DIY fender rolling.
Stone chips, small dents and scratches in line with mileage.
LED interior lights flicker sometimes
Front fender liners are torn and loose
Right front window regulator beginning to make noise going up down- works fine.
Required maintenance of supercharger system- clean oil line filter yearly, drain Oil Catch Can every 2 months or 2000 miles, blow off valve and oil drain hoses are original and will need replacing- oil drain hose wet, Clean MAF every 6 months.
Radio turns off every 25 mins, have to turn back on. Don't know why it does that.
Transmission chatter at idle from single mass flywheel- normal condition.
Asking price $12000
Tim Ng- 678-464-1603, s14realm3@hotmail.com
Car is in North Atlanta, Georgia
Picture link: https://drive.google.com/folderview?...nSKAg_L9ViW9qE
Tim
CCA#36497
2003 ZHP 6 spd
95 M3 BuzznM3
92 S14ic M-technic
91 M3 classic
Tim
CCA#36497
2003 ZHP 6 spd
95 M3 BuzznM3
92 S14ic M-technic
91 M3 classic
Tim
CCA#36497
2003 ZHP 6 spd
95 M3 BuzznM3
92 S14ic M-technic
91 M3 classic
Looks really good! Good luck with the sale!
Google Drive link gives400. That’s an error.
The requested URL was not found on this server. That’s all we know.
email me s14realm3@hotmail.com and I will share
Tim
CCA#36497
2003 ZHP 6 spd
95 M3 BuzznM3
92 S14ic M-technic
91 M3 classic
bump
Tim
CCA#36497
2003 ZHP 6 spd
95 M3 BuzznM3
92 S14ic M-technic
91 M3 classic
