Results 1 to 15 of 15
Thread: Control Arm Bushings
    Jul 2016
    South Carolina
    1986 325e 2001 330ci
    I read the DIY about pressing out the old ones and pressing in the new ones. I did that but getting the pressed in bushing onto the control arm....yeah....
    So far I've tried lubricating the arm and twisting the bushing on it. It's a new Lemforder control arm and the bushing that came with the set. I can't even get it on the shaft to level much less all the way in.
    Anyone got some tips on that?
    Oct 2003
    Seattle
    99 M3
    Either the proper FLCABushing tool, a homemade variant or a dead blow hammer and a deep socket/dead blow hammer…and dish soap
    Joliet,IL
    87 325is 96 GMC Suburban
    What did you use to lubricate it? I think I have used WD-40 and possibly armor all, otherwise dish soap/water
    Sep 2014
    KS
    e24e30e36e39e90
    I used my 13 year old son and a floor jack. But any helper will do. Set the lollipop on top of the floor jack, sitting on a pvc pipe or anything that will allow the control arm to poke through. I pushed the control arm into the bushing with all my strength and weight while my son pumped up the jack. Easy peasy. Unfortunately I had already wasted a lot of time with other methods of trying to get it on. I used dish soap as a lubricant.
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    Put the bushings in the freezer overnight, or at least for a few hours. A piece of threaded rod, some fender washers and nuts worked for me.
    2004 525i Sport, Manual - 1985 325E Coupe Manual
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    i think they are talking about putting the lollipop bushing onto the actual control arm, not the one into the lollipop.
    No e30s again.
    Joliet,IL
    I had the best luck connecting the control arm to the car first at the inner/outer ball joints, then lubricating the stub and rubber bushing, twisting it round until the bushing is indexed
    Apr 2015
    Toronto
    e30s
    I put the control arm in a vice. Lathered on dish soap or equivelant on the shaft of the control arm and in hole of the bushing. the first time around I could barely get it over the end. I pulled it off and the 2nd attemp with a twisting and pushing motion it slid over the control arm shaft. Done. works everytime since.
    Jul 2016
    South Carolina
    The problem is I broke the ball socket in my right arm and can no longer put all my weight against something. So I just took it to a Russian shop that repairs BMW and they got a guy that looks like a bear in a jumpsuit. He chucked it up in a 6 inch vise and when examining the control arm said "Is usually smooth not have ridges"
    He then pushed so hard the bench started moving and they went right on.
    $20 later and I'm ready to go
    Dec 2005
    No e30s, again :(
    ha ha ha, thats a funny story but at least it was cheap
    No e30s again.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    This should really be done with the CA already bolted to the subframe since you have very little time to get the car on the ground so the CAB can find it's neutral state on the CA before your lube dries. The bushing sets to the CA and will not rotate once it's dry so if it dries out of place it becomes preloaded and will self destruct long before you'd like it to.
    just sayin
    87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
    87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
    Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
    New "made in Europe" seat shocks. PM for details
    http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
    Jul 2016
    South Carolina
    Quote Originally Posted by Jeffnhiscars View Post
    just sayin
    I see your point. I just got back to the project and am trying to break it free with penetrating oil
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by clovett View Post
    Don’t use oil!! LOL!!! Pull the ‘lolly pop’ off and reinstall with dish soap.
    Jul 2016
    South Carolina
    Thanks for the input guys. When I had the shop put these on I took the originals and laid them side by side. It was so close to perfect it didn't matter
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    If you are concerned that they may be preloaded take a map torch and VERY gently warm the CA (not the bushing). This will relax it enough for it to reset....and DO NOT melt the damn thing !!
  1. how hard is it to change control arm bushings?
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 07-18-2001, 03:20 PM
  2. Control Arm Bushings
    By 540Rob in forum 1991 - 1999 (E36)
    Last Post: 07-07-2001, 02:17 PM
  3. HELP!!When do I know if control arm bushings need replacing
    By bimmermike in forum 1991 - 1999 (E36)
    Last Post: 06-07-2001, 10:11 AM
  4. How many labor hours to replace lower control arm bushings?
    By Kritpoon in forum 1992 - 1999 M3 (E36)
    Last Post: 04-17-2001, 01:41 AM
  5. how easy is it to replace control arm bushings?
    By joeyc in forum 1991 - 1999 (E36)
    Last Post: 03-10-2001, 02:04 PM
