Results 1 to 4 of 4
Thread: Helpp Leaking Convertible
    Nov 2018
    Israel
    Bmw 1 Series Convertible
    Hello,
    I have BMW E88 I120 ,Model 2009.
    I have leaking water from the fabric of a roof over the corner on the right side of the rear window and on the side next to the driver.
    Is there any solution to put something in for fixing it? I tried spray of a waterproof and it did not help.
    Pelican Parts's Avatar
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello and welcome to the forum! You may have to replace or fix the seal that is causing it to leak.
    888.280.7799 | 6am - 5pm PST
    Nov 2018
    Israel
    Hello,
    Thanks for respect.
    Which kind of seal I have to fix ?
    I'ts leaking from the canvas.
    Florida Panhandle/ Ohio
    14 JGC/13 E88 128i
    If it is leaking from the canvas then you have not waterproofed it sufficiently. What did you use? 303 is a pretty good waterproofing product so is Raggtop which makes a whole kit. My experience with the cloth tops is that unless you see it coming through the cloth it is the seal. BMW uses rubber not synthetic seals and they shrink over time. Verify it is the cloth and if so waterproof it a couple times according to the directions. Most state once the top is clean you can spray the sealer on and recoat once dry within the hour otherwise the next day. Every leak I ever had in my convertible BMWs was from the seal shrinking...
    BMWCCA 149159
  1. leaking convertible top
    By zeak in forum Middle Atlantic - US
    Last Post: 03-28-2013, 10:39 PM
  2. Leaking Convertible Top Piston
    By aerosurfer in forum 1999 - 2006 (E46)
    Last Post: 01-06-2011, 02:12 PM
  3. Leaking Convertible
    By kelo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-08-2008, 04:45 PM
  4. Leaking Torque Converter Seal
    By Avery540 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-14-2005, 07:21 AM
