Hello guys,
In the fabric of my roof over the rear window on both sides of the car there is a leak of water in the strong rain, dripping water on the back seats of the car, there is some substance or something to put in order to seal it?The rubber bands are normal, everything is normal in the car except for the leakage of the water on the roof.
Remind again - the hole is in the fabric of the roof probably and from there there is a leak, the hole is not visible.
Thanks.In the fabric of my roof over the rear window on both sides of the car there is a leak of water in the strong rain, dripping water on the back seats of the car, there is some substance or something to put in order to seal it?The rubber bands are normal, everything is normal in the car except for the leakage of the water on the roof
You can take similar material with some silicon glue and patch from the inside. Also not a bad idea to use 303 or Raggtop to waterproof the cloth top.
BMWCCA 149159
