Hi!
I'd like to know if one of you guys could take a look at your sensors' connectors, and tell me what wire colors are in what position, and if it is the same on each side.
I need this information for CRANK, Cam (intake) and Cam (exhaust).
Official BMW Z3 1998 shows:
Crank sensor / Cam Sensor Intake / Cam Sensor Exhaust
Position 1: Yellow (doc says ge = gelber = yellow)
Position 2: Black (doc says Sw = schwarz = black)
Position 3: Shield
In my case, the Crank sensor side has:
Position 1: Black
Position 2: Yellow
Position 3: Shield
The harness side has:
Position 1: Yellow
Position 2: Black
Position 3: shield
On my car, one of the camshaft sensors had been obviously tampered with because the shield wire (sensor side) was with the black wire (harness side).
I'm trying to bring the car back to what it was originally. The Link instructions are clear: one of the sensors will be wired with reversed polarity. To use their own terms: it is not a mistake. Hence, it is important that my wiring be "original" when I'll be plugging one of the wire reverse to the other two sensors..
Thanks in advance!
Frank
