Hi there,
On my 2004 X5, 3.0i, I've got the engine light on. The car starts and runs perfectly fine. I took out the DISA and Idle valves. Cleaned them both, tested Disa, flap works fine with the hole closed and open; the Idle valve rattles fine after cleaning. It was kind of stuck prior to cleaning. Put everything back on cleared the code P1092, and P0420, started the engine, after 5 or ten minutes of driving the light came back on.
The full scan is show below for before and after cleaning. I use the Foxwell scanner for BMW, slow but thorough. and I still have the P1092 & P0420.
Any help is much appreciated.
Fault Codes (Before cleaning Idle valve)
E9 DME: Catalytic-converter efficiency, bank 1
EB DME: Trimming, oxygen sensor before cat., bank 1
8D DME: Plausibility, tank fill level
1F DME: Activation, ignition, cylinder 5
3 DME: Activation, ignition, cylinder 6
2 DME: Activation, ignition, cylinder 4
D2 DME: Error, ign.-current measurement at more than 2 cylinders
F2 DME: Misfire, cylinder 5
F3 DME: Misfire, cylinder 6
F1 DME: Misfire, cylinder 4
Status Report (After cleaning Idle Valve)
D1 DME: Anti-tampering protection EWS
How long has the check engine light been on ??
