Results 1 to 5 of 5
Thread: Request: how to remove touring rear seat back
    Reno
    E46M3, S52T E30, E21T
    Would anyone like to share with me a somewhat detailed "how to" on removing the folding rear seat back on a touring?
    I tried pulling up on the side bolster, but it didn't budge. In fact, I heard it rip a bit...
    I'm guessing the bolster covers some nuts/bolts that need to be removed for the seat back, but without getting the bolster off I'm kinda stuck.
    What an I missing my dudes?
    Thanks in advance.
    DWR
    CURRENT:
    Racecar: '81 e21 320i Group2. GT28 @ 25psi, MS2, e28 M5 suspension/brakes underneath, forged, cammed, 400bhp, 2190lbs, etc, etc...
    Daily: '95 e34 540/6. DUDMD tuned, vogtland/koni, Schnitzers, other minor touches.
    Project: '94 525iT. S50 swapped, supercharger in the works, manual swapped, Airlift supsension, Mpars, Brembo's, clean machine.
    New daily: e60 530i sport package. Stock.
    CT
    '94 530iT LSx/T56
    Its been a LONG time since ive messed with mine, but curious what your trying to accomplish? Remove the seat bottom and sneak a look at the bottom of the side bolsters. I think theres a stud there with a plastic 10mm nut on it. The pop the top seat belt trim up. I think it had a screw under the side trim, so start at the back with the trim removal. Couple screws, couple pull clips. Once thats removed, you can pull the bottom of the bolster out and then up. I believe the top is held in with a tab in slot. Removing the actual seat backs is pretty easy as well. At the 60/40 split, theres a bracket at the bottom. Remove the clips, slide them sideways, and out they come. They are a lot heavier than you think theyll be.
    -Alex
    Reno
    Quote Originally Posted by AHenry014 View Post
    Thanks Alex,
    I'll look at that tonight. I'm removing them to have them recovered in Black.
    CURRENT:
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    The seatbacks are held down in the center by a bracket and a 18mm (IIRC) bolt. The side bolsters have a hook on the bottom and a straight snap/clip near the top. Remove the seatbelt trim, pry the bolster forward with your hand, and sneak a long prybar until you hit the snap/clip. The clip is sturdy metal, no plastic.
    Reno
    Quote Originally Posted by moroza View Post
    Thank you. I still haven't gotten to this yet, but I sure do appreciate the tip. I'll dig in again this coming weekend.
    CURRENT:
  1. Removing Rear Seat Backs in Touring
    By IamCatman in forum 1996 - 2003 (E39)
    Last Post: 10-07-2010, 11:25 AM
  2. need help removing rear seat back rests in my 328
    By toopercentmlk in forum 1991 - 1999 (E36)
    Last Post: 05-04-2007, 03:43 PM
  3. Rear seat back removal...How?
    By Drea///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-04-2003, 02:16 PM
  4. Removing Rear Seat Back
    By 10kken in forum 1991 - 1999 (E36)
    Last Post: 03-27-2003, 10:12 AM
  5. How to remove Rear Seat Back?
    By e_schickdu in forum 1991 - 1999 (E36)
    Last Post: 01-06-2003, 07:22 PM
