eBMWParts
Results 1 to 6 of 6
Thread: Aftermarket Suspension Brace Questions
    Nov 2018
    Denver, CO
    2011 Subaru Outback
    Are those aftermarket braces that go from front suspension tower to tower designed to be in compression or tension? Also, what is the correct terminology used to describe (what do you call them)?
    Dec 2013
    Chicagoland area
    EXOTICS
    Called a strut tower brace.
    Neither compression nor tension upon installation.
    Google:BMW strut tower brace
    then take your pick of the options offered.
    Oct 2003
    Seattle
    99 M3
    For an E36, the X-Brace provides more stiffness than the Strut Tower Brace
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by bluptgm3 View Post
    I believe an E30 benefits because the Strut Tower Brave ties into the firewall
    Aug 2013
    1999 BMW M3 Coupe
    Yeah, first thing to do is the x-brace underneath since that will do far more by tying the chassis crossmember into the front subframe so it's more difficult for them to twist independently under load. The strut tower brace on top is mostly for decoration, though a quality one can add some stiffness as well.
    Dec 2013
    Chicagoland area
    EXOTICS
    As posted above, the x-brace should be the primary modification for stiffness,
    followed by a strut tower brace for additional stiffness.
  1. Question About Aftermarket Suspensions
    By RichardEllis in forum 1999 - 2006 (E46)
    Last Post: 01-31-2008, 05:47 PM
  2. suspension/brace question
    By skatewakesnosur in forum 1991 - 1999 (E36)
    Last Post: 08-11-2006, 04:44 AM
  3. Strut Brace Question
    By dronell19 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-12-2002, 04:09 AM
  4. x brace question...........wow
    By thug life in forum 1991 - 1999 (E36)
    Last Post: 07-06-2001, 04:17 PM
  5. Suspension Install Questions...
    By joeyc in forum 1991 - 1999 (E36)
    Last Post: 03-08-2001, 11:50 PM
