Results 1 to 15 of 15
Thread: Need help, what intake boot for eurosport supercharger?
    Madison, WI
    2003 M3, 1998 M3 TS
    I recently bought an e36 M3 with a eurosport supercharger, the intake boot needs to be replaced, but I cannot find the part anywhere. It's not an e36 boot since it has a hose outlet on top and bottom... Does anyone know what the part # is for the intake boot between the HFM and throttle body?
    2.1L Eurosport Twin screw on the 98 m3. Please send tires.
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    Quote Originally Posted by Truman325i View Post
    PM Randy Forbes since he is the Twin Scroll guru around here.
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Pretty sure it's 540I elbow.
    Now, what year, and how modified?
    2001 below
    milKt's Avatar
    I remember that tab on the HFM side
    Madison, WI
    2003 M3, 1998 M3 TS
    I thought it was that elbow as well, but couldn't confirm it had a barb opening at the top for the supercharger breather hose. I couldn't confirm that from any of the pics, and I couldn't confirm if it went from 3.5 at the HFM to 3 at the throttle body.
    The car is a 1998 cosmos black which I believe has been around a few owners on this forum. TRM coilovers, maganflow exhaust and some other goodies. Mostly trying to make sure everything is as solid as possible and ensure the car is running right and producing all the power it safely can.
    milKt's Avatar
    Maybe I'm wrong,
    TANKS is on his way, with green tip TS knowledge.
    Oct 2003
    Seattle
    99 M3
    TRM Tuning is current retailer (according to Eurosport website) for the Eurosport Supercharger.
    milKt's Avatar
    Quote Originally Posted by bluptgm3 View Post
    LOL
    funny...and sad
    NY
    skateboard
    Quote Originally Posted by milKt View Post
    LOL
    funny...and sad
    Indeed
    ― George Orwell
    Madison, WI
    2003 M3, 1998 M3 TS
    and they haven't returned any of my emails or inquiries. Anyone know the best way to get a hold of them?
    Maybe I'm wrong,
    TANKS must be lost...lol. I read some of his old threads, so hoping he chimes in, he knows his shit.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Didn't I send you the part number in an email, or something?
    (you should post the pt no here, for future reference)
    As stated, the original boot was a modified piece, with the ICV port cut in/bonded on. The port piece might've come from an S52 boot...?
    Madison, WI
    2003 M3, 1998 M3 TS
    You did send it, and I got it all put together and running this morning. I'll post part numbers, procedure for modifying the boot and some other misc info later. It was a lot more involved than I thought it would be.
    Thanks All!
    SW Florida
    Thanks All!
    Said EVERYONE that ever converted an engine to forced induction
    Madison, WI
    2003 M3, 1998 M3 TS
    Putting some things here and will expand later if necessary
    You need two boots:
    13-54-1-740-073- This is the donor boot for the ICV port connection
    13-54-1-438-761-U-INT - This is the boot that is the main connection
    - You basically cut the port and sliver around the port and need to attach it to the other boot. To attach, I did mine directly below the port already on this boot for the crankcase breather. You just need to cut it to fir in the section below that is demarcated by the ribs. line it up, mark where you need a hole and drill the hole, then attach this donor port/flap. I used gorilla super glue gel. In tests it seemed to hold the best. Need to act quick though to make sure it seals well.
    Misc stuff-
    Clamps
    Gel super glue
    Hose clamps 3 and 3.5 in
    air hose connector- 13-41-1-722-944
    misc vacuum line connections. Likely a 3/8 in 90 degree connection and then a 3/8 to 1/4 connection so that you can tie into the factory breather valve.
    SW Florida
    You need two boots:
    Misc stuff-
    Clamps
    Gel super glue
    I've brought the ts parts/repair list thread back to the front page, so I really encourage you to copy/paste your post to it. Collectively, we've tried to contribute to our continued twinscrew longevity by posting the odd bits of parts sourcing information in there as we find it.
    https://www.bimmerforums.com/forum/s...ts-Repair-List
  1. need help with intakes for euro E46 M3
    By ibrahim83 in forum 2001 - 2006 M3 (E46)
    Last Post: 03-07-2005, 12:49 PM
  2. Need help installing intake
    By ledzep244 in forum 1991 - 1999 (E36)
    Last Post: 02-15-2005, 10:47 AM
  3. Changing Head gasket, need help removing intake manfold!
    By Ali in forum 1992 - 1999 M3 (E36)
    Last Post: 03-08-2003, 01:55 AM
  4. Need help with intake for 99 323i please...
    By madsedan in forum 1999 - 2006 (E46)
    Last Post: 05-08-2002, 10:11 AM
  5. Need help finding Intake Air Temp. Sensor
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2001, 04:52 AM
