Dinan
RMS
VF
Other
Though I would start a poll at to who has the best Supercharger Bracket; Design, strength, and for big boost, Etc.
There’s only one company that does that for the S52; RMS.
The newer style RMS, not the older Dinan copy.
• Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
I voted RMS
Vf offers the least chance of belt issues. Add an intercooler setup, and a smaller pulley you have a nice setup.
― George Orwell
Rms.
Sias Tuned, Vortech Blown, 3.2L S52...456WHP/360WTQ
Sias Tuning | HowertonEngineering | Davis Motorsports Club
Yes. Not apples to apples to i6, but I modded my pulley set ups on my VF 540. Running 16 psi on only a 6 rib belt with no issues. Been running it for years now. Pulley wrap is the key to get the traction.
https://www.bimmerforums.com/forum/s...tock-M62/page2
post 36 starts dets. w/a intercooler added later in thread.
Not sure of the limitations on with the i6 kits, but some clever thinking should be able to get a better pulley set up.
I like the belt wrap mod. Maybe there is space to do that on the E36. But does the M62 have a bigger crank pulley than the S52?
Thanks!
M62 VF crank pulley is 6" dia. A tad bigger than the i6
VF S52 crank pulley is the stock accessory drive pulley and is more like 5”. Big difference. The old RMS stage 2 S52 extended dedicated drive crank pulleys were 6.0”
Ok. But 8 vs 6 cyl.
That's certainly an S52/M52 setup__and Very Impressive!
In the poll, I clicked other, but that's just because I'm a much bigger fan of the positive displacement twinscrew compressors. Sourced 2nd-hand, either the Active Autoworks or Eurosport setups turn up from time to time (I've done several 2nd, 3rd generation swaps). Unfortunately, both brands combined totaled less than sixty (<60) units ever on the market.
