Results 1 to 3 of 3
    Enterprise, AL, usa
    1997 BMW 318I, 2015X535D
    Run Flat tire size differential Front to Rear?
    Hey guys, my first post so bare with me, just bought a 2015 X5 X Drive 35D and wow is it a sweet machine. Torgue out the ying yang! Right now it has a staggered tire arrangement: Pirelli P Zero run flats, Front 275 40 R20 and Rears 315 35 R20's. I would like to put the same size tires all the way around so that I can rotate them regularly as in past cars. Routine rotation increases tire life and makes me inspect the brakes and bonding surfaces between wheel and hubs regularly. I would like to know if these tires have the same circumference? Are the rear rims wider than the front rims? Would it be possible to put say, 285 40 R20 all the way around? (Plus the 315 35 R20's are like $60 bucks more per tire!) Thanx in advance for any input, I appreciate your help. HF Hop Collin
    Jan 2016
    Ca
    2001 525it
    Talk to the tire store
    Apr 2009
    Surrey, BC, Canada
    740iS, 745i, 528i
    Tires are the same circumference but the rims are wider in the rear. I’d suggest to not try to go that route; keep the staggered figment. I have the same vehicle with the staggered size and they are all wearing very equally. You have to replace all 4 at the same time anyway so stay with factory sizing. The extra $60 over the life of the tires is well worth it.
    Sent from my iPad using Tapatalk
  1. Running different tire size in fronts
    By blizzak in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-06-2010, 04:08 PM
  2. run flat tires and winter tires
    By llaroo in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-25-2005, 08:05 AM
  3. Tire Pressures? 44 front----48 Rear?
    By Ocean's M5 in forum 1988 - 1996 (E34)
    Last Post: 02-27-2005, 02:16 PM
  4. What is the widest tire size for stock rims? (rear)
    By Emmasis in forum 2001 - 2006 M3 (E46)
    Last Post: 05-01-2004, 01:38 PM
  5. AutoX with Run Flat Tires
    By Hallatauer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-13-2003, 01:38 PM
