Results 1 to 2 of 2
Thread: Aftermarket HU Install with stock HK Amp and Speakers
    Sep 2013
    FL
    99 M3
    OEM head unit bit the dust recently going to replace it with an aftermarket deck.
    Wanted to double check I have this correct, taken from:
    https://www.bimmerforums.com/forum/s...1#post26812971
    Quote Originally Posted by StereoInstaller1
    My favorite trick to interfacing an aftermarket deck to a stock BMW amp is simple: use chassis ground on the speaker level negative inputs.
    Basically, I do not connect the aftermarket decks speaker negatives to anything, simply insulate them. Once the positives are connected, grounding the amp input negatives drops the aftermarket decks voltage to a far more acceptable level. The deck then runs cooler and overall SQ is improved by not overloading the input stage of the amp.
    If you meter the output of your stock deck, you will see all 4 speaker negatives are chassis ground anyway, so all it does is replicate the factory systems output.
    So I am going to not wire and insulate the negative wires leaving the aftermarket head unit and then the negative wires coming to the head unit I need to ground them to chassis aka something metal, so bunch together those negative wires and ground them to a spot on the metal chassis in the dash
    yes? no? thanks.
    '99 M3
    '82 320i
    Port St Lucie, FL
    1998 M3/4/5
    I just installed an Alpine unit in my 98 with the 10-speaker HK system. I just spliced in the existing wiring to the adapter and did not isolate the speaker grounds.
    It sounds much better than stock and I have a lot more input options. If I wanted a truly stellar system I would replace all the speakers, the amp, all the wiring, and use a much higher quality head unit.
  1. '99 328 wiring diagram/aftermarket HU install help
    By mcastleberg in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-28-2008, 01:17 PM
  2. FS: antenna adapter cable for aftermarket HU install
    By dswads34 in forum Car Audio & Electronics
    Last Post: 07-09-2007, 02:04 PM
  3. E39 Aftermarket HU install and MID display -- questions
    By BlackSapphire in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-28-2007, 01:42 AM
  4. aftermarket amp installed where stock amp is
    By stylzs in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-01-2005, 12:27 AM
  5. FT: My Aftermarket HU for your stock one
    By Wally in forum BMW Parts For Sale
    Last Post: 11-15-2004, 10:49 AM
