Lots of work done, was front running GTS3 car with stock S52.
Now it has S54, locked cams (VAC VANOS delete kit), Throttle by wire VAC delete kit. It can be ran by any Megasquirt modules.
Moton Suspension front and rear, rear coilover conversion, Ground control rear shock monoball mounts
Ground control camber plates
Custom roll center correcting ball joints, with spacers
Ground control bump steer kit
Ground control tubular sway bars
Ground control trailing arm bearings
Ground control rear lower control arms with monoball
Rear cross member solid bushings
Solid motor and transmission mounts
Everything is reinforced, and some panel stitch welded
3.64 differential, with active cooler
Stock 5 speed ZF transmission
Clutchmasters FX725 twin disc ultra light clutch
Full cage, integrated into rear cross member mounts, and through the firewall into front strut mounts
Front and rear Brembo brakes
Fire suppression system
Cobra seat with head protection
AKG tall shifter
Communication radio
Lexan rear windows
I'm sure i'm forgetting lots of other stuff.
Car wasn't driven in the while. Was converted to S54, but never finished. Engine is in the car, needs FI moded to run, or install VANOS and run BMW ECU. Have many spares.
Looking to get 15K, located in Los Angeles
Dmitry Gluskin
BMW M3 GTS3 #475
2009 NASA Nationals 2nd place finisher!!!
nice
― George Orwell
have any pics?
Pictures are not working
https://imgur.com/lPuM3Rq
https://imgur.com/azWkZJ7
https://imgur.com/EDW4V54
https://imgur.com/MabO7c5
https://imgur.com/iqGIb3a
https://imgur.com/MAUcnIj
https://imgur.com/BWrCQbB
https://imgur.com/tL959AR
https://imgur.com/Is0sD0P
https://imgur.com/iEanFDw
https://imgur.com/9UvO3aI
https://imgur.com/Q68ErwN
https://imgur.com/4mKTAHe
https://imgur.com/aZRAMPp
https://imgur.com/DzFdPB5
https://imgur.com/JWQVdYd
https://imgur.com/6Ulht4e
https://imgur.com/438xjau
https://imgur.com/9b3yD5l
https://imgur.com/LhOwqLg
https://imgur.com/lp7wfgV
https://imgur.com/fkuemuZ
https://imgur.com/VVTTmWS
https://imgur.com/INNFfhJ
Dmitry Gluskin
BMW M3 GTS3 #475
Pictures are up
Dmitry Gluskin
BMW M3 GTS3 #475
Wow, great price!
Harrison Motorsports
Motion Control Suspension
Daytona M3
