Hi everyone. I'm replacing my head gasket on my 05 325xi. I was checking my block for flatness and noticed my cylinder Sleeves are sticking up... Only in the middle where cylinder walls are the thinnest... These are uniform across the entire block. I'm going to try and post some pics... Pic#1 is where they are high. Pic#2 is flush with the block. My question is... Is this normal for my sleeves to be higher in middle for sealing the combustion chamber. Do I have a problem??¿? I'm not sure I can post the pics...
Yes, you have a problem. Your engine does not have sleeves. If it does, an idiot has been there, and you should just buy a used engine. They run $500-$1250. I don't fix head-gasket M54's anymore, it costs the customer 3 times as much as replacing them.
You can use a non Xi engine if you swap oil pans.
Chris Powell
BMWCCA 274412
OP, you need to post 10 or 15 valid posts before the software will allow you to post pictures. Did you overheat the engine? If you did, you need to figure out why the engine overheated and correct that problem before you overheat the “new” engine. There are a ton of used M54 engines out there. Make sure you buy one with a warranty.
WOW ! Holy Dumbass!
Big Mike, you have my most sincere and contrite apologies. I've had dozens of these completely apart, and never seen a sleeve..
Ross, thank you for correcting me....I'd rather be a dumbass once, than repeatedly. Now, if I can just get my size 12 out of my mouth....
I'd still stay with the recommendation to replace the engine though. As many as I've had apart for a head gasket issue, the vast majority had warped the head, and pulled the threads out of the block. Yes, you can put Time-Serts in there, with an expensive fixture for aligning the drilling and tapping....but a replacement engine is going to be much cheaper and easier.-
Chris Powell
BMWCCA 274412
I agree buying a used, running, compression tested M54 engine (or one from a dismantler with a warranty) IS the easier / cheaper way to go, but its close to doing a headgasket depending on your machine shop costs. And even if you do replace the engine, consider putting the overheated engine on a stand and rebuilding it as a spare or for something to sell. While there are plenty of cheap M54's out there now, that wont last forever. M52TU's are already becoming scarce in some areas. I cringe every time I hear an overheated M54 engine is tossed in the scrap heap.
I rent the time-sert tools (kit 1090 with the jig) as well as the M54 timing tools. PM if interest
