Results 1 to 13 of 13
Thread: 325iX Questions
    Maryland
    89 325iX
    325iX Questions
    I know this question probably gets asked a bit on here and I have done some research prior to making this post. I am looking at a 89 325ix auto tomorrow morning and was hoping to get some last minute advice on what to look for on this car. It has 220k miles with a few service records. I know i want to do the Viscous coupling test and to check shock towers and the body and underside for rust ect.....but what specific iX stuff do I need to be on the lookout for? I know brake sand suspension are specific to the iX but anything else? I have been out of the BMW world for about 5 year now after I sold my e46 and I am really looking to get into a 325iX. Thanks in advance for any help!
    Estacada Oregon
    E30M3 X2 R100GS/PD R60/5
    Quote Originally Posted by BMWBurnout875 View Post
    Also look for torn boots on front axles and axles that pop on hard turns
    Look for stripped splines on front driveshaft, or loose tcase chain causing poping on accel.(look at fluid condition in tcase)
    Oh and look for rust everywhere
    Sent from my SM-G960U using Tapatalk
    Angus
    88 E30M3 X2 (1 summer/1 racetrack)
    89 325IX (winter)
    92 R100GS/PD
    Maryland
    89 325iX
    Quote Originally Posted by spdracrm3 View Post
    Will definitely do that, also he said the sunroof doesnt work is that a common problem or an easy fix? if not its not a big deal, also mentioned that the gas gauge is "bouncy" whatever that means.
    Estacada Oregon
    Depends if manual roof could be broken handle stripped gear or misaligned cables. Add bad switch relay or motor for electric roof some are easy to fix cables and tracks can be tedious
    Gas gauge on my 225k is starting to become erratic (sensors are no longer available,assume e85 fuel is affecting them) I'm starting to just go by odo a fill at 300 miles.
    Angus
    89 325IX (winter)
    92 R100GS/PD
    Aug 2016
    EastCoast
    2001 740i
    325ixs are cool parts can be a pain in the ass to find I just tried ordering transmission cooling hoses for it and received the wrong item a lot of parts numbers for the ix will say one thing and will match up perfectly online on “realoem” and then you try to install it and it doesn’t fit I had that happen to me a lot do yourself a service run away from the headache get anything but a ix.
    Maryland
    89 325iX
    Thank you all for the replies. I have decided to purchase the car I looked at. The body/paint and interior were a solid 8/10 the drivetrain was also a 8-9/10 but the motor has a rough idle but the whole cooling system was replaced. I decided to buy it and fix the idle issues. Im so happy to be back in a BMW again!
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    sweet!!
    No e30s again.
    May 2018
    Pittsburgh
    1991 325ix
    check the strut housings as well. Both of mine were done for. Not cheap to replace.
    Maryland
    89 325iX
    Quote Originally Posted by T81Houston View Post
    yes I just got the cra up on stands the other day and noticed that there are quite a few bushing that need to be replaced. The strut housings arent too bad but first I must track down this rough idle issue im having.
    Maryland
    89 325iX
    Just doing some research on the gas guage issue and im finding that the fuel sending unit next to the fuel pump sends the guage the level of fuel left in tank. So this could be the problem? They do make these still so I thought it was worth mentioning.
    Estacada Oregon
    Might be two sensors as well ,one on each side of saddle tank
    Angus
    89 325IX (winter)
    92 R100GS/PD
    May 2018
    Pittsburgh
    1991 325ix
    My strut housings didn’t look to bad but upon closer inspection they were completely rotted out on top. No threads left at all, it was all rust holding the caps on.
    I ended up replacing the intake tube on mine. Cleared the idle up some since it was dry rotted. I’m currently tearing down to do timing belt, tensioner and water pump. Already have the plugs, wires and cap replaced.
    Beat of luck!
    Maryland
    89 325iX
    I ended up replacing the intake tube on mine. Cleared the idle up some since it was dry rotted. I’m currently tearing down to do timing belt, tensioner and water pump. Already have the plugs, wires and cap replaced. Beat of luck!
    Im basically doing the same thing to clear up a rough idle. I have a completely new thread to keep track of my progress. I have a bunch of gaskets and o rings being delivered today so i will update my post if anything im doing fixes the problem.
  1. 325ix questions
    By awahl in forum 1983 - 1991 (E30)
    Last Post: 10-18-2006, 11:58 AM
  2. 1991 325ix questions
    By uberkb in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-24-2006, 06:11 PM
  3. 1991 325ix questions
    By uberkb in forum 1983 - 1991 (E30)
    Last Post: 06-24-2006, 04:23 PM
  4. About to buy 325iX, Questions!
    By rgordon1979 in forum 1983 - 1991 (E30)
    Last Post: 12-13-2005, 01:52 PM
  5. Newbie- 91 325iX questions
    By Kuhl 951 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-25-2005, 07:04 PM
