Results 1 to 11 of 11
Thread: M635 / M88 Shims
    North Central Florida
    88m5,2015 Silverado
    M635 / M88 Shims
    Need a single 4-10... Have a nice set and multiples of almost every other M88 and S38 shims, but need this one to complete the job, anyone out there have these and want to sell or swap some shims ?
    thanks !
    Edit to say I found 1 of the ones I needed, now only need the 4-10
    Spartanburg, SC
    85 M635, 98 Z3, 00 528iT
    I have a set of shims at home. I will check and see if I have an extra in this thickness and let you know. They are officially shims for VW and not BMW shims. Let me know if that is a deal killer for you. No offense taken if you want BMW shims.
    Eric
    88m5,2015 Silverado
    VW shims are fine , no problem at all, thank you !
    North Carolina
    '86 M635/'10 Clubman
    Seems like I heard Volvo shims are correct also.
    Also Greg in MD has a set - I think. I'll ask him to get in touch if he does
    Spartanburg, SC
    My understanding was that Volvo shims work in the S38 and VW work in the M88. M88 shims are slightly smaller in diameter compared to the S38 variant. If I am incorrect, someone please correct me.
    Oh, and I didn't check on the 4-10 shim last night as I forgot it was Halloween and was in full dad mode after I got home. Sent a reminder to myself for this evening. Sorry for the delay.
    Thanks,
    Eric
    88m5,2015 Silverado
    Thanks to Eric, shim is on the way. FWIW, engine got dropped into place today and headers are on the studs ( total pain as we know). I have always used a cherry picker in the past, but this time I used a hoist suspended from the I beam across my place here...wow, so much nicer, more controlable and any tiny amount of movement is easily done, perfect
    Lou. Ky.
    87-635 '78-R80/7 '96-960
    I also drive Volvo's. There is a company called "IPD". They've been making Volvo performance parts for a long time. If they still do it you can rent a valve shim kit. You put a deposit down on the kit and pay only for the shims you use . Comes with a depressing tool, an assortment of shims and whatever else is needed for a valve adjustment.
    88m5,2015 Silverado
    I have a ton of shims and the tool no problem. Just needed that 1 shim. Thanks
    Spartanburg, SC
    Quote Originally Posted by dm635 View Post
    That is a really cool service. If you have an S38, this seems like a good route to go to keep costs down (assuming their shim prices are decent).
    Glad to help out on the 4-10 shim. Good luck getting everything buttoned up.
    Eric
    Lou. Ky.
    Quote Originally Posted by 88m53453 View Post
    Yep,I figured you had everything needed except for the one shim. Just adding it in case someone needs that info sometime down the line. If IPD does still do it it is a great service. Have no idea if the depressing tool works on the M or not.
    88m5,2015 Silverado
    Fwiw. Careful use of the tool will allow use on the M88 and S38, at least with the tool I have , results may vary and I am not responsible if anyone breaks an expensive part while trying..etc etc
  1. FS M88 Valve tappet leveraging tool and misc shims
    By EuroGeorge in forum 1976 - 1989 (E24)
    Last Post: 04-03-2018, 08:53 PM
  2. FS: BMW M635 valve shim removal tool rare
    By amthatiam in forum 1976 - 1989 (E24)
    Last Post: 07-03-2014, 09:31 AM
  3. M635 M88/3 Head Wanted
    By puldu in forum BMW Parts Wanted
    Last Post: 07-22-2007, 09:25 PM
  4. Anyone with GC RTAB inserts/shims every have or
    By Drea///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-06-2003, 11:00 PM
  5. I had a scooby snack this eve //M635 vs WRX
    By e34biturbo in forum Kill Stories
    Last Post: 12-09-2002, 11:17 AM
