Results 1 to 10 of 10
Thread: Time for new fuel pumps
    Oct 2008
    Mt. Dora, Florida
    Alpina B12 5.7, 850 CSi
    Well...after almost 3 years into the restoration, it was time to finally fire up the 5.7. Last time it was ran was about 2 years ago. Cranked fine. Did not fire.... I had removed the fuse in the Alarm, and was wondering if that might have had something to do with it, so I put it back in - no change. I spoke with Wuffer and Steffen, and we all agreed - check the fuel pumps. Before checking the pumps, I made sure that the new fuel filters were put in correctly - that the arrow was pointed toward the engine side of the lines, not the tank side. Check - I had not screwed that up. Tom suggested that I make sure the DK motors were humming - which in turn would indicate that the large fuseable links in the trunks were good - DK motors buzzed. Good. Next - removed the rear passenger seat and checked the plug to make sure power was going to the pumps, ensuring that the fuses and relays were OK - had power to both pump + wires. Next - check the pumps independently by connecting to a 12V source directly - I did not have a spare battery. So I just made a long + and - set of wires from the batteries in the trunk (they were new, and have been on a battery tender). I connected this to the + and - at the pump....walla…...no sound from either pump. Now...to make things more difficult, I had just filled the tank with new 93+ octane non-ethanol gas. So, I will make a mess when I have to remove the old pump and place the new one.
    Oh well....got to call Gault in the morning on Monday and spend more money. There is a reason that Marcia calls the car the ALEXPENSIVE.
    Editor, E31 NEWS - BMWCCA E31 Chapter Newsletter
    North America Representative, 8er.or Board of Directors
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    i put a new fuel pump unit in a few weeks ago…. was surprized by the price…. expensive pumps .
    Could also have just replaced the 2 pumps and the 4 worn rubber supports , if those are still available… but OK, i opted for a complete new unit.
    There were already 2 different pumps in it , so a PO must have it done in the years ….
    Forgot to order the big rubber ring gasket … reused the old one.
    recently car was very lean on one bank or even bank "dead" .... must still test it but possible a new pump already died…. ? Fuse is OK , still relais to check.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    +1 on the new rubber gasket - it makes life so much easier. You will definitely want to siphon about 5 gallons or so out of the tank or you will have several gallons of fuel running out of that big opening once you crack it open (learned that the hard way the first time I every opened that years ago). Keep a bunch of damp towels on hand just in case.
    '93 850Ci - Mineralweiss Metallic
    ALPINA B7 -Alpinweiss III
    BMWCCA E31 Chapter President
    Mar 2011
    So Cal Ca
    BMW 850i
    Yes! +1 on the new gasket purchase.
    May 2013
    Salinas CA.
    1993 BMW 850CI
    Check out a handy device in a case called a GassTapper. Works like a champ, and for those who live in areas with frequent power outages that use a gas fueled generator, it is a way to easily get gas out of the car. You won’t have to store 5 Gl. And worry about it going stale.
    Dec 2013
    San Antonio
    850i, '76 2002, '76 530
    I just watched the Gas Tapper video and saw where they used two hoses, one inside of the other, to get siphon line past obstruction in filler neck. I wonder if this would work on the E31? I couldn't get a siphon line into tank through the neck when I needed to remove pumps but this trick might just work.
    Dec 2007
    Dallas, TX
    I use the wheel centering pin from the onboard toolbox to hold the anti-siphoning flap open, and insert the hose to get the fuel out.
    Sep 2011
    Vancouver Canada
    91 850i 91325iC 01 330Ci
    Roger - I just sent an e-mail to you re pumps. /Henry
    Oct 2008
    Mt. Dora, Florida
    Thanks Henry for the information! I just ordered 2 new Bosch OEM 69493 pumps for $200 plus shipping for the pair. The cheapest I could find for a new BMW Fuel pump assembly was from Scott at Gault was $499 (retail was around $650).
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by rogbmw View Post
    I'd be interested to see if you can get to all the clamps to the fuel lines going to the pump carrier. When I changed the carrier/both pumps on the CSi as much as I tried, I could not get to one of the clamps. Such an annoying oversight. You are left with two options. Neither of them very appealing.
    I joke with another fellow 8er that the day they put that piece together in the factory, Hans was out for a long lunch. Hans is my generic (yet endearing) representation for a German engineer .
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
  1. How to know when it's time for a new fuel pump?
    By VARick in forum 1983 - 1991 (E30)
    Last Post: 09-08-2015, 06:50 PM
  2. Fuel pressure won't hold!! & Is is possible to ruin a new fuel pump?
    By HeißeScheiße2 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-21-2007, 02:43 AM
  3. New Fuel Pump Relay...still no go
    By uncletammy in forum 1975 - 1983 (E21)
    Last Post: 06-07-2005, 01:14 PM
  4. Brand New Fuel pump E36 1992-1995
    By nmoe in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 10-22-2004, 03:35 PM
  5. Do I need a new fuel pump?
    By stevewen3 in forum Forced Induction
    Last Post: 07-02-2003, 08:09 PM
