Results 1 to 3 of 3
Thread: charging by external charger, is it safe?
    Oct 2018
    Europe
    E63
    Could I charge the battery via the
    "so-caIIed jump-starting terminal for jump starting" * under the hood?
    This car will not drive every day and now this gel battery has only 12.12 Volts what means 40% charged.
    * there is a description in the user manual about emergency firing from an external power source, but there is NOTHING about slow recharging.
    Connecting jumper cabIes
    To avoid personal injury from sparks, foI-
    low this sequence when connecting
    jumper cabIes.
    ln your BMW, the so-caIIed jump-starting termi-
    naI for jump starting in the engine compartment
    sees as a positive termini for the battery, aIso
    refer to engine compartment overview on
    page 2 1 7. The cover cap is marked with a +.
    1 Fold open the cover of the BMW jump
    starting terminaI. To do so, puII the tab.
    2. Attach one end of the jumper cabIe pIusI+
    to the positive terminaI of the battery or a
    jump-starting terminaI of the vehicle provid-
    ing assistance.
    3. Attach the second end of the cable to the
    positive terminal of the battery or to a jump-
    starting terminal of the vehicIe to be staed.
    4. Attach one end of the jumper cabIe minus/-
    to the negative terminaI of the battey or to
    an engine or body ground of the vehicIe
    providing assistance.
    Your BMW has a special nut as body ground
    or negative terminal.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, charging from the 'jump start' posts is the recommended way to connect - you can't connect to the battery terminals as this by-passes the IBS. But, if you want to do it properly try this:
    https://www.meeknet.co.uk/e64/Timms_...n_the_Boot.htm
    My BMW Repair YouTube Channel
    Jan 2016
    Ca
    2001 525it
    Get a battery tender, hooked it up shut the hood lock the car, avoid jump starting your car regularly. You can leave the battery tender hooked up for ever
  1. Turbo Charging Vs. Super Charger
    By NakedAsaltGerbl in forum Forced Induction
    Last Post: 09-23-2006, 02:30 PM
  2. Replies: 7
    Last Post: 05-23-2006, 03:01 PM
  3. how to charge car battery safely?
    By bassit in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-10-2003, 08:11 PM
  4. how do you safely charge/discharge a capacitor?
    By NoSoup4U in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-28-2003, 12:06 AM
  5. Help!! How to safely remove a charged capacitor???
    By JT-KGY in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-12-2001, 03:09 AM
