Is anybody here running the IRP short shifter kit? I want to see how it compares with the rtd shifter or cae ultrashort. At half the price is it worth it? Comparing the bottom of the barrel on these short shifters to the top. I really want the CAE or RTD was thinking of getting one more affordable for now and selling down the road as long as the performance is worth it.
I did search for this but really only found info comparing the RTD to the CAE but nothing of the IRP or samsonas shifter to those.
I installed an IRP on a member's car recently. Other than it having rattles here and there, it's way more pleasant to use than I thought it would be. I went into the install dreading the decision.
IRP does rely on the transmission detents for centering. I know some other brands have heavy springs built into the shifter. Personally, the IRP felt amazing so I don't know that I would want a self sprung shifter unless it was being used a detent-less SMG transmission.
Install photos.
I bought the RTD today. Very excited
I have a friend who went back to aftermarket stock style after using one of those on his street car that he also drag raced. With stiff or solid mounts they work best, and stiff or solid mounts are no fun on a street car.
It’s the 2-3 shift that is slow on my car, and that has been true with 3 ZF320, detents changed on all. Flywheel is stock weight dual mass but aftermarket Southbend clutch that is stiffer, and UUC EVO3 with DSSR. I am beyond the limits of the ZF320 power holding and that may affect shifting.
I will be going to a GS6-53 and twin disk this winter and hope that will help. If not, I may try a captive shifter trans like a T56 Magnum.
That’s good to know. I ONLY drive this car on the track though and to and from. It’s got really stiff trans mounts with the aluminum cups and really hard motor mounts. I used to miss 3rd and would hit 5th coming around the last turn but with the stiffer mounts no sir. I’m hoping this will make the gears even tighter.
I haven't tried any either, I'm sure the feel is nice. But yeah as others have mentioned you have to run stiff mounts or else I think there's too much movement. I guess I'm fairly happy with the Bear Motorsport setup I have... though I think I may try to go to a taller knob than the ZHP I have on. Maybe like the stock one, or stock weighted option there is.
[QUOTE=Braymond141;30135009]Cheap out? The IRP is $450. It's not cheap by any means.
Well when the part varies from 450-1200 I don’t want to get the cheapest one and expect what I would out of a more expensive shifter. Like tighter shifting, less noise, self centering spring and colors I want
Plus the fact that I can’t find to seen anyone that has one. I don’t want to be the guinea pig and not like it, not be able to return it or sell it. So I went with what a lot of guys seem to like
Find people who have street driven one for a couple of years. Solid mounted shifters work best with little engine/trans movement, which means stiff mounts, which aren’t fun to street drive. Maybe this IRP is not as hard core since it relies on the stock trans detents, and is not spring loaded.
The thing is I don’t care how it performs on a street setting. This is my track car and is not driven on the street so it’s irrelevant. I have very stiff mounts as well becasue it’s not street driven
We run an RTD in both of our race cars. One is a champcar that uses stock rubber mounts for both the motor and trans. Once you get the shifter adjusted correctly the mounts make no difference. The only issue we had was before we adjusted, if you were braking real hard in 4th it would pull itself out of gear. Moved the mount foward and the issue was resolved. Our other car is a spec car and its got solid mounts everywhere and it feels great. Its really hard to drive a car without an RTD in it now.
1995 M3...Screwed
CAE - 1200$ and is made in Germany and IRP - 600$ and is made in Lithuania... think think think... is all about politics man... look for IRP V3 self centered, great reviews, is used in a lot of racing app so.. I don't think you'll ever brake it )
I went with the RTD. I ABSOLUTELY love it. Well worth the money. Took a little getting used to but I can’t imagine going back. Haven’t had a chance to get on the track yet but luckily/unfortunately I’ve had to daily my track car for 2 weeks so I’m used to it now lol
I've ran RTD in my track only car since 2016. I've had two shifters, the non-lockout and more recently the now outdated cage style with reverse lockout.
Maher changed the design after the guys at CAE started calling him out for copying their design. He proclaims his innocence and has relocated the locking mechanism underneath (vs above like the CAE) like any other businessman with integrity.
RTD is legit.
You get a shifter that's about 90% the same quality and performance as other way more expensive cage style shifters for about 50% of the price. People love to talk shit about RTD to help defend/justify their overpriced shifter, but I almost never hear of failures with RTD.
I personally have never had a problem with either shifter and Maher has always been quick to respond to any and all customer service questions.
10/10 would buy again!
Older non-locking:
You can see the shifter in action here:
Yeah, awesome. Just sharing my experience.
