I think something like their "service wrenches" come close. There are a ton of options for thin wrenches: https://www.garagejournal.com/forum/...d.php?t=285207
What I found worked was a pair of small Craftsman RoboGrip adjustable pliers. They're thin and the jaws are always parallel so you get a good grip on the flats of the endlink. Seems like pretty much everyone hates these things but they worked a treat for me on that one specific job.
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
Okay it turns out it's still leaking...so the seals are probably shot. Maybe. Tried tightening it up a but and the bolt won't budge. Tried loosening it and also won't budge. Of course I don't have a lot of leverage in there so I went and found a crows foot that would work (turned out mine had hooks on the ends of the tines that kept it from engaging, but a set with straight tines works fine). But I can't get it seated properly...if I try to use a ratchet down by the bolt I don't have enough clearance and I don't have a straight shot to use extensions and a swivel from up top.
This is a seriously frustrating problem.
It was suggested that unbolting the engine mount and lifting the motor slightly on that side would clear some room...is that a viable option?
I never had it off...I really don't know the history of this situation, I got the car with it leaking so bad that it would empty the system in less then 20 miles.
It's just the one bolt going down from the top, correct? Or do I need to do both of them? Should I also need to unbolt the mount from the chassis if all I'm doing is just trying to get some room to change this washer?
Now that I think about it you need to replace both washers on the banjo bolt, one on the top and the one on the bottom of the banjo bolt. Grease will hold the washers in place while your trying to thread the bolt in.
http://www.realoem.com/bmw/enUS/show...diagId=32_0927
The top bolt on the motor mount is a PITA to get at, you'll need a few long extensions.
You could take the 2 nits off of the bottom of the motor mount, that would be much easier.
When you jack it up make sure the fan doesn't hit the shroud. Check for any other hoses and wires that might get pulled on.
Yeah I want to replace both the washers...which wouldn't be a problem if I could just get a couple inches of room in there. I just need need to get a real wrench on the thing
Undid the motor mount on driver’s side (surprise! Mounts are shot) and got the bolt out. Was super easy once the motor was up a couple inches. Now I can’t get it back...the line has it in a bind. Nothing easy I suppose.
These cars make you "earn it".
I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
The law does NOT determine "right" from "wrong". They are unrelated.
If you put cheap parts on your car, you will soon have a cheap parts car.
Didn't I say it was going to be a PITA job?
If you have the other end of the line disconnected it should be easier to get the banjo bolt in.
I was simply confirming the prediction.
I’m undoing the other end tomorrow morning to take another go at it. Fixing everything on this car going to takes at 20 minute intervals.
F I N A L L Y
I had to disconnect both hoses from the pump to get it. I took the opportunity to remove the one in question to inspect it and it had, indeed, taken a hit sometime. I think with it's proximity to the engine, when the engine mounts being completely gone (the motor just lifts right up out of the them on both sides), at some point the motor got acquainted with the line and things were not the same after. I gave it a slight tweak to the get the angle a little more favorable and it bolted right up. New washers all around, no leaks.
NEXT:
Getting the exhaust patched up. Also getting new mounts but that's really not too big a project. I'm probably just going to have a shop do the exhaust...I'm a little tired of crawling under it for a while.
Neat. Move the car back so I can lay down some kitty litter (I basically drained the whole PS system on the driveway...oops) and I find this waiting for me
Access to i.imgur.com was denied
You don't have authorization to view this page.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I don't get it. If you click the address bar and just press enter it goes straight to the website. If you just copy the link (https://i.imgur.com/YZPoeKZ.jpg) to your address bar it goes. But if you click the link from this forum, and only this forum, you get "access denied"...
If I open it up in a new tab I see a green something, antifreeze?
2003 M3CicM6 TiAg
Former:
That’s the thing...it’s just this forum. My other forums imgur works just fine. You can even put the image in tags and it works. Not here. Might be because of the way BF changes the link, don’t know, oh well.
But yeah it’s antifreeze. Just a couple drops from the right side of the engine, toward the rear. Thing has nearly 300k on it, though...probably about time for a cooling system refresh.
