Results 1 to 2 of 2
Thread: Turner Motorsport- NEW F80/F82 S55 Oil Catch Can
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    New Turner Catch Can for F80/F82
    Shop Turner S55 Oil Catch Can Here
    The Turner F8x M3/M4 S55 oil catch can was designed with a strategically positioned 4 chamber baffle system with an added easy drain feature. The intent behind this design was to offer the most effective oil/air separation while being incredibly easy to maintain. The included drain kit allows you to route the drain hose to a mounted location near the belly pan of the vehicle making it convenient to empty at oil change intervals.
    Modern day emissions regulations require the use of a closed crankcase ventilation (PCV) system to recirculate combustion blow-by gases from the crankcase back in to the intake to be burned. Unfortunately, these blow by gases contain water vapor (which is a byproduct of combustion) and pick up oil mist from and the windage cloud and cam lubrication system as they travel through the crank case. Due to less than 100% effective air/oil separation in the stock PCV system, some oil mist and water vapor gets carried back to the intake tract and over time cause oil deposits in the intake manifold, intake ports, and on the back of intake valves. All will eventually lead to poor performance and reduced fuel economy, and the presence of this oil mist in the intake charge may even increase the risk of engine-damaging detonation.
    With forced induction, track use, and/or extended high RPM usage, these symptoms increase as the factory PCV system is overwhelmed, and a catch can becomes a must for your F8x M3/M4 S55.
    Features:
    • 6061-T6 billet machined body, anodized black for lasting protection and appearance
    • Strategically positioned 4 chamber baffle system maximizes oil / air separation
    • Knurled and black anodized oil dipstick makes inspecting oil volume of reservoir clean and simple
    • Sealed with a pre-installed o-ring
    • Includes 2.5mm allen key to remove baffle plates for cleaning
    • Engineered to create multiple changes in the direction of airflow within the separator to cause oil droplets to fall out of suspension before exiting the catch can
    • Closed / recirculated design reduces oil ingestion and promotes cleaner emissions and odor-less operation
    • Valved drainage system - no removal of can necessary to empty
    Call or email us today! 800.280.6966 or info@turnermotorsport.com
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    Mar 2001
    BMWs and Mini's
    Turner Motorsport
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
  1. Turner Motorsport NEW PRODUCT. E46 M3 Bosch Motorsport ECU System
    By E36HellRotM3 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 10-15-2013, 05:08 PM
  2. Behr e36 Radiator from Turner Motorsport, New in Box - SOLD
    By ziggysux in forum Engines, Performance Parts & Software
    Last Post: 09-09-2013, 12:59 AM
  3. <Elephant Motorsports> New product - CAST DTM Oil Pan
    By RacerX in forum 1987 - 1991 M3 (E30)
    Last Post: 02-11-2010, 02:50 PM
  4. FOR SALE: E36 suspension kit from Turner Motorsports - NEW!!
    By PinoIX in forum Pacific Northwest - US
    Last Post: 08-25-2009, 01:15 AM
  5. Turner Motorsport - New Supporting Vendor
    By TurnerMS in forum Vendor Comments & Supporting Vendor Info
    Last Post: 10-17-2004, 06:57 PM
