Results 1 to 9 of 9
Thread: 2008 535xi Touring - Will 16" wheels fit?
    Oct 2018
    Massachussettes
    2008 535xi Touring LCI
    Hello everyone,
    I am looking to put together a winter wheel set-up together for my 08 e61. I just recently placed an order for some 16x7 5x120 +ET20 steelies. I'm looking to run some chunkier tires (225/55/16) which is why I am specifically looking for 16's. Will these wheels be able to clear the brakes (rotors and calipers) safely? Any insight on the matter is appreciated.
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    ET 20 won't fit a 4x4. You will need a ET 40ish. Look at this.
    http://www.bmwstylewheels.com/5/E60+
    Oct 2018
    Massachussettes
    Thank you jtbgonesailing - could you please explain why the +ET20 wouldn't fit?
    With +ET43 on my stock set-up (style 243 wheels), the wheels sit very deep into the wheel well and I don't like the look of it. I am currently on M3 CSL reps that are 19" +ET35. Even +ET35 sits deep into the wheel well so I am using 10mm spacers in the front and 17.5mm spacers on the rear to have it flush with the fenders.
    Is this bad for the x-drive system? If so, I would totally revert back to the stock set-up to spare myself the damage.
    Mar 2008
    Monroe, CT
    2007 530xi 6 spd.manual
    On an E60 xi car, the minimum wheel size is 17" because 16's won't clear the brakes. The offset for xi cars is about ET 34-45, otherwise they won't fit properly. A 225 size is the minimum you should consider for a snow tire. Steelies will look like crap on a BMW. You can do better on Craigslist with used OEM wheels. Just my opinion.
    2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
    Oct 2018
    Massachussettes
    Thank you for your insight JayArras - I am considering your opinion. Personally, I do not mind the look of steel wheels. I think they look decent on the car.
    I contacted the manufacturer of the steel wheels - they do have a size that fits the BMW X1 (E84) - size 7.5x17 ET34. However, the manufacturer says that they are unsure if this will fit as steel wheels have a backspacing that may or may not interfere with the calipers.
    I will look into OEM options - though craigslist and Facebook marketplace has very little options in my area.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Quote Originally Posted by JayArras View Post
    I bought a used set of 17” alloys for my winter wheels back in 2011 for my 08 E61 535xi Sport (factory 18s). Such wheels should be cheap now. Just get a straightness guarantee — spin them on a car and look for wobble. I have used 215/50 and 225/45 for snows. Some 215 have sufficient load rating. Not sure if there is room to fit 225/50. I never tried. Within 3% diameter of stock is fine.
    Oct 2018
    Massachussettes
    To my knowledge, my E61 stock wheel/tire set up is 225/50/R17. Can someone confirm this?
    Feb 2010
    Atlantic Beach, Fl
    Quote Originally Posted by Binh.n54e61 View Post
    Take a look at the drivers B pillar. Tire fitment size and recommended tire pressures are listed.
    Jun 2005
    New England
    Maybe they are. I have not bought in a couple of years and found be confusing with my E36M3 snows. I have 3 BMWs and 3 sets of snows. All are in storage right now so I could not check.
  1. Will any 16" BMW wheels fit over M3 front brakes?
    By BigBlueM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-11-2009, 04:59 PM
  2. 16" steel wheels fit an E36 M3?
    By Jay Barthelotte in forum 1992 - 1999 M3 (E36)
    Last Post: 01-03-2007, 10:18 PM
  3. Do E36 16" Steel Wheels Fit E46???
    By mreda in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-10-2005, 02:31 PM
  4. Will 16' E36 wheels fit on E46
    By BiMmEr JoN in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-17-2004, 08:57 PM
  5. 2000Z3 16*7 wheel fit E36?
    By Dragon Ball in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-11-2001, 09:27 AM
