Looking for some replacement front seatbelt receivers, I not familiar with all the direct replacements from other models so maybe if someone has a list it would be helpful. My front seatbelt receivers plastic peices are broken I have them rigged with Rubber bands.
I *think* I have these. Let me confirm tonight. they would be from an 81.
Ok Thanks for looking
Temporary fix not pretty but functional
sent a pm
Finally got around to fixing the seatbelt receivers today with the parts I picked up from jaredmac11. The finger, the black piece, that is the tensioner is what broke in my case, which seems to be flimsy IMO. I managed to replace them with the 2 from the used parts i purchased, the trick to removing and installing them with out breaking is to lock the receiver without the belt then the Press button slides off and the finger comes out. Installing in reverse order locked belt then it slides on. The black cover seem to be glued so I decided to use tie straps instead of glue. FYI The back and front receivers are the same, which was key to my success cause I had one of each.
Excellent. Happy to hear. They look great.
Thankful I didn't need to remove the original receivers that would have been an ordeal.
