Results 1 to 11 of 11
Thread: Wheel skipping when cornering, E36 trackday car
    Aug 2017
    Antwerp
    E36 328i track car
    Question Wheel skipping when cornering, E36 trackday car
    Hey,
    I have a problem with my E36 328i, it is a track car only. I build it for 1 year and did my first trackday with it recently and had a litte problem.
    When I was taking sharp corners, one of the rear wheels seemed like skipping/vibrating/hopping ... idk what it was but it felt really bad or the car.
    I assumed the diff was a welded diff but yesterday I opened the diff and it seems like the diff is in good shape. It is a BMW stock LSD (s2.93)
    So now I don't know what would have caused the problem... below some pics of the diff
    Other info:
    Drove with semi slicks, has sports supsention, stock rubbers, faster less tight corners no problem...
    If you can help me in any way, thank you!
    Tom
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    The clutch plates inside the LSD could be damaged, which could cause the wheels to lock unpredictably. Can't really tell without taking the whole unit apart though. What's the age of the diff?
    Sep 2010
    mid-atlantic
    70's p-cars
    ASC off?
    Nov 2001
    Parker, Colorado
    GTS3 E36, 97 M3/4/5
    Which wheel was it? Was it the unloaded wheel (usually inside)? Were you trail braking?
    Oct 2003
    Seattle
    99 M3
    Are you running fluid for LSD, Red Line 75W140 for instance with friction modifiers?
    Aug 2017
    Antwerp
    E36 328i track car
    Thanks for the anwsers,
    I don't know what fluid was in the diff, never opened it before...
    I will look into opening up the diff, is this a hard job to do?
    I don't think it was ASC, felt diffrent
    It was the inside rear wheel I think that acted weird, I wasn't trailbraking the problem occured in het second pat of the corner (after the apex)
    EDIT: I can try opening up the internals of the diff and take a look inside (clutch disks etc.), do you guys think this might give answers? Its a lot of work tho for just looking
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Silly question, but are you CERTAIN is wasnt the inside FRONT wheel skipping? My consistently lifts 3-4 inches during cornering and will "bounce" as the vehicles weight distribution starts to correct. Very common on e36's especially with stiffened front sway bars.
    Aug 2017
    Antwerp
    E36 328i track car
    It certainly wasn't the front wheel, tha car also has original sway bars
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    Sorry if this is not helpful, but: With stock suspension and bushings, the chassis can roll around a lot. Are your semi-slick tires rubbing the fender or the wheel well liner a little, when the body leans way over in a hard corner and then the chassis shifts back under acceleration off the apex?
    It happened to me once when I put slightly larger tires on a sport suspension E21 at the track.
    But probably not. Tire rubbing would make loud noise, but it would not make the wheel hop or lose traction.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    joenationwide's Avatar
    joenationwide is offline Makes Cars Dance BMW E36 M3 Expert
    Leesburg, Virginia
    95 M3 (GTS2), 99 M3
    Yeah its probably a worn out diff. Same thing happened to me in my race car. Inside rear wheel would hop exiting tight turns. Got a new diff and now it is butter.
    Apr 2018
    Bay Area San Jose
    1998 M3 Sedan
    I have the same problem, my inner right would skip going downhill on freeway ramps (right turn)
    Thought it was my blown rear right shock but had a feeling it might be my diff as well
  1. My E36 Trackday Car
    By carlhaakon in forum BMW Rides & Events
    Last Post: 01-09-2017, 05:22 AM
  2. Rear wheel skips when cornering
    By R1101001 in forum 1999 - 2006 (E46)
    Last Post: 08-04-2014, 07:57 PM
  3. E36 Track Car Wheels/Tires Recommendation
    By siamesecat in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-13-2012, 09:31 AM
  4. E46 steering wheel on E36 Airbag car?
    By S14 in forum 1991 - 1999 (E36)
    Last Post: 08-14-2009, 11:58 AM
  5. Req: Smoke Clear Corners on e36 Black Car
    By rcristobal in forum BMW Rides & Events
    Last Post: 09-26-2004, 10:58 PM
