Results 1 to 8 of 8
Thread: Any tips pr advice on removing and installing the blower motor and wheels ?
    Apr 2014
    cincinnati
    1986 bmw 735i
    I dunno how anyone can remove or install a blower motor on a E23 its nearly impossible. Do you disassemble the motor and wheel and re-assemble onside the cowl area ????
    Jan 2016
    Ca
    2001 525it
    I thought that at the back of the engine compartment there is a panel you remove and there it is, as I remember
    Mar 2013
    USA
    E21/early e23/e34
    It's a pain, ideally it comes out from inside the car, I've only removed the blower motor/fans from the outside and was able to do so and not break the squirrel cage/covers. Motor and fans/wheels come out as a whole, It's possible to reinstall from outside but slow and easy and lots of patience, it's possible. I'd probably slightly pull the bottom lip panel out a little.
    May 2013
    Killingworth, CT
    '84 733i, 01 X5 00 750iL
    Working through the cowl on the engine bay side, the blower motor comes out and goes back in w/ the wheels on it. I have done a few of them. Be patient. There is barely enough room but there is room.
    Steve H.
    Apr 2014
    cincinnati
    1986 bmw 735i
    Thanks guy's ....im headed to the store to buy some patients then gives this a shot lol
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    I hope to calm you involves an adult beverage!
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Hamburg, NY USA
    e23, e32, e34, e39
    Lots of back pain medication, lots of patients, some luck.
    I did it probably ten years ago and still hate it.
    Definitely from outside the car- engine compartment area.
    There's JUST enough room to squeeze the cages out from the compartment. Make sure you note how they go in and test before you button it all up.
    Good luck!
    Apr 2014
    cincinnati
    1986 bmw 735i
    FOLLOW UP : Well i got the blower motor in and it takes patience and very tedious maneuvering. The black plastic casing that the squirrel cage sits inside of is the most complicated to get out. The motor and squirrel cage comes out as one whole unit.
  1. Replies: 21
    Last Post: 07-15-2013, 08:06 PM
  2. Any Tips or Advice are Greatly Appreciated
    By E39Saloon in forum 1996 - 2003 (E39)
    Last Post: 07-23-2010, 05:25 PM
  3. Replacing Water Pump/ TStat - any tips or advice?
    By Ahheck01 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-29-2006, 03:58 PM
  4. E39 Tips for guage cluster removal and installing chrome rings
    By WheelsDirect in forum 1996 - 2003 (E39)
    Last Post: 07-28-2005, 04:39 PM
  5. Anyone have any tips/instructions for tint removal?
    By Ben Carufel in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-13-2002, 12:53 PM
