Nice progress! This is looking more doable now that you have the subframe set close and the engine tucked in there. Nice video actually. GG should watch it!! The fore/aft location of the subframe looks about spot on, but I'd get some more measurements from another E39 and maybe and E60 to confirm. The caster and strut angles will affect the tire clearances as the steering is turned stop to stop. Might be a good to remove the spring from a strut and then move the steering stop to stop with strut compressed and also fully extended. The tire corners are very close to hitting the fender liner and fender lips on a stock E39 when you run bigger meats like 275-35-18's. It would be interesting to see how this plays out. Good luck and keep going. I like the "garage" you are working in!
Freethrow, nice avatar.
This reminds me of a story from my youth. One friend suggested the use of a Chevy V8 manifold on a Ford V8. Another friend rejected the idea because it would not fit. The first guy said, "Ever try to make it fit?"
Watch the third video as it shows subframe related stuff ignore the first two they won't be worth watching for you
Good shout on removing the spring I hadn't thought of that!
I'm hoping to get some rough subframe mounts welded on this weekend if I can borrow an arc welder of a mate (don't worry a mig is on the way) this is just for temporary mounts to get it held in place so I can get it back on its wheels. I have another E39 to compare wheel positioning too like you say. I might struggle on E60 measurements though.
Regarding the wheel clearance I think using the E60 parts will give me me the same track width as running 20mm spacers on the E39 setup. So roughly I would be running et-1 if I run my 0058 rondells on here. I'm not sure what tire clearance will be like at that only time will tell.
Haha thanks yeah the garage isn't great but it's getting better, the roof of the old barn I'm in has been "fixed" should keep the water out now. Next step is power and lighting save relying on a torch all the time. Then onto closing the front opening off just in time for winter setting in. Progress might slow down depends on how cold it gets lol .
I'll try and live out to your story and make it fit
540i 6spd DUDMD tuned-weekend brute, sounds like an M5 throaty V8 "Vtec-ish" cam noise.
Hummer- 35inch MT's, Adventure offroad package.
check out my video gear
https://kit.co/Lv5multimedia/mobile-videographer-set-up
Best Oil hands down for bmw
https://www.amazon.com/gp/product/B0...1441c0abde2552
Subscribed
Sent from my SM-N960U using Tapatalk
Watched a bit of your last fitment video. Have you considered running the engine without the plenum? Maybe running some velocity stacks and an Alpha N tune, such as the one sold my 2M Autowerks??
Also, how the front wheels sit inside of the wheel well can be remedied by adjustable caster plates, which you would likely be doing anyways, as im sure you'll be changing the coilovers anyways to compensate for the added weight up front.
I suggest this as its more important shifting your focus on getting the steering linkage set in place versus worrying about caster that can be adjusted out later on
Sent from my LG-H932 using Tapatalk
I didn't really want to run velocity stacks as the car will be run all year round so in all weathers.
I know what you mean about caster I'm more concerned about getting the wheels in the correct position inside the arch and if this means adjusting caster later then I'll get adjustable top mounts. Moving the subframe back and forth does move the wheel back and forth within the arch so it's all a balancing act of subframe/wheel/engine placement all battling eachother.
Ive made some small progress on the project, I got some temporary mounts welded onto the shell. I had a couple of goes in different places to get where I think it needs to be but I need to do more measuring to confirm this though.
So here's how the car sits now back on its wheels with the engine sitting on the subframe unsupported
And even better the bonnet closes also!
Check out the monster arch gap
So now the next mission is onto the steering column which isn't going to be easy looking at the angles.
I can't go any further with the subframe mounts till I've looked at the column.
After looking at the column I'll try fitting a header and no doubt I'll have clearance issues there....
So some progress made but still all up in the air with so many variables fighting eachother constantly.
Just came across this v10 e46. Thought I'd share...
https://youtu.be/NZ5w5YvrSKs
Update on my progress is now on YouTube, it shows working steering!
https://youtu.be/XJXyKvHvSd4
Sorry for the lack of updates but I'm currently waiting on parts for the coilovers from the states still over a month now which is stopping progress.
I've also had rod bearings turn up so that's another job onto the list.
I took delivery of this yesterday which is the other side of the project. Its an M5 that has been stripped for parts, the plan is to have a V10 E39 in an m5 shell. The shell is straight just has rust on rear arches and sills that needs sorting.
Subscribed!
Very cool project. Videos of the finished car would be appreciated!
Well, the hard work is the figuring it out bit..., so, if he likes the blue M5 shell better, swapping the loaded subframe over is trivial in comparison.. Damn that is one stripped out M5 though. I'm amazed it still has the trunk lid, given that they took everything else.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Was thinking the same. I bet it's rusty under the lip.
But yeah, hard part is the fitting work. Good luck on project!
Trunk has the VIN tag.
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
In for updates. This is uber cool
Diehard E39 driver.
I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
"Your momma's so ugly she makes Bangle cars look nice"
Thanks! It'll be a long time before it's completed I imagine though!
The work I've done on the i6 shell has never been permanent as this has been the plan all along, the i6 shell is for mock up then transfer over to the M5 shell once I'm happy with the fitment.
The shell needs quite a bit of work in the form of rust repairs, the i6 shell has gone in similar places also.
Yeah it is pretty stripped, its been used a donor car for a touring swap. It did have doors on but they where removed so we could lift it by hand off the trailer, the trunk lid is badly rusted around the microswitch as usual .
Indeed, very rusty!
Thanks it's going to be a long task now .
The sticker under the number plate is always a good check to see if a cars had paint in the past .
^Every chassis I've ever shoehorned the "wrong" engine into had to be cut, welded, tweaked, and adjusted to get everything right. Doing it with the I6 shell to get the details hammered out is the best way to go if it's an option. It's secretly the reason I haven't hauled my I6 parts car to scrap...some day I'd really like to cram an LS or coyote motor (or something weird like a Cummins) into it.
I’d say a Coyote... nothing like that blue oval thunder, short stroke 302 !!
The Coyote is good but it's not really anything special, might as well use an LS, the 5.2L Voodoo on the other hand...
Nothing like revving a V8 out to 8500rpm :-)
