Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: *E53 2002 BMW X5 4.6is Silver/Imola RWD LSX Project*
  1. #26
    Jul 2006
    335ti 360ti x5-6.0tt
  2. #27
    Jul 2006
  3. #28
    May 2001
    Plymouth, MI 48170
    1999LSxSwapped 557i & X5
    Not a huge update but finally putting on the finishing touches before drivetrain gets pulled to be gone thru. 4" from the Downpipe back. Converted to Throttle by cable as well. Driveshaft should be done this next week.
    E53 LSX Swap Coming Soon!
  4. #29
    Long Island
    E34 535i
    Wow. Nice..... love the intercooler/radiator setup. Are you eliminating A/C?
  5. #30
    Jan 2014
    SF, CA
    S/C LS2 e46, LS e367&8
    I’m interested in a mount kit.... I think.
  6. #31
    Washington
    BMW 525i
    I wish it was easy to keep awd... I love the idea of a turbo ls e53 but awd would put it over the top.
    2002 BMW 525i - 6.6L LS Turbo Swap
    Follow me on Instagram at @LantzFab
    Link to LantzFab.com
    Link to my Facebook page
    Link to my build page
  7. #32
    Jul 2006
  8. #33
    Jan 2014
    SF, CA
    Ok. Yep. Now I need to build one.
    Someone have a set of mounts for sale?
  9. #34
    May 2001
    Plymouth, MI 48170
    I can make you a set in the beginning of the year. I'm about to yank my drivetrain back out to go thru everything and then I can make jigs for the mounts. You will be able to run Factory Pickup Truck/ Van Front Dress Accessories and Oilpan so swapping should be extremely cheap if you want to go budget build on this chassis.
  10. #35
    Washington
    BMW 525i
    Quote Originally Posted by Bmwman528e View Post
    I’m not even done with my current swap but I really want a E53 after seeing these build threads.
  11. #36
    Jan 2014
    SF, CA
    That sounds good. I’m assuming you’ll drop the part number for the oem exhaust manifold after payment?
  12. #37
    May 2001
    Plymouth, MI 48170
    TCI Outlaw Shifter finally came in after weeks of waiting on the part. Really wanted to go with the stock bmw shifter but I ended up going this route. Driveshaft turned out pretty slick. Getting close to the complete teardown stage and then final assembly. All hot side parts will be ceramic coated satin black. I will be running a Holley Terminator X Engine Management System. Haven't picked my Torque Converter out yet. Lots of options out there for my 4l80e.
  13. #38
    Jul 2018
    Louisiana
    Bmw E39 528i
    Looking freaking awesome man, glad to see more people using the Sonnax adapter and a single piece drive-shaft. I like the look of the shifter, stands-out but probably is more satisfying to use.
  14. #39
    Dec 2015
    Central Arkansas
    1999 BMW 740iL
    I need info on an e39 kit, if you can message me,,,, thanks... Nice build here btw...
  15. #40
    Jul 2006
  16. #41
    honolulu
    2000 740i sport
    Any updates?
    No new updates over here other than I scored a used M5 driveshaft to cut up and make a custom 1 piece to the M5 differential. Was able to get it for $150!
    Any updates to share? Very interested in converting my own 4.6is to an LS .... particularly interested in total parts cost so far ...
  17. #42
    Dec 2023
    Maine, USA
    05 e53 x5
    I'm starting a ls swap on my 05 x5 but not gonna lie I'm not a fabricator and don't know the first thing about welding so I'm curious how much you would charge to fab and ship some motor mounts and trans crossmember to maine
  18. #43
    May 2001
    Plymouth, MI 48170
    Feel free to shoot me a text as you don't have enough posts to send a PM too yet. 734-780-6477
  19. #44
    Jul 2011
    Houston
    LS e39, LT e53,
    have you started the LS swapped x5?
    On my 5.3 L83 swap, Im not running a fuel control module, the fuel pump is wired up like an LS. I'm running a GSS342BX fuel pump with a e46 radium fuel pump adapter to fit the OE sending unit and a 5 bar return fuel setup all -6 fitting from the x5 fuel filter quick disconnects.
    at 70 psi I have this weird rhythmic (maybe every 4-5 seconds) thumping noise from the fuel tank, I'm think its something to do with the siphon jet or something.. very strange. I lowered the fuel PSI to about 60 psi and the noise is reduced... have you came across this yet? I haven't put many miles on the swap, still fooling with other projects.
    nice work on your swap by the way
    Clint
    2003 X5 4.6is - for sale
    2006 X5 L83 5.3 6l80 swapped in progress - for sale
    1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff - for sale
    2007 ZX-10r - sold
    1987 R-10 SWB L83 5.3L 6L80e swapped
    www.87chevy.com
  1. Replies: 20
    Last Post: 10-22-2020, 10:17 PM
  2. 2002 BMW X5 4.6is Imola Red - SOLD
    By ImolaRedx5 in forum BMW Cars For Sale / Wanted
    Last Post: 12-31-2014, 11:07 PM
  3. 2002 BMW X5 4.6is underride guard
    By dannypiv in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 06-21-2011, 05:22 PM
  4. 2002 BMW X5 4.6is
    By Hit Redline in forum X Series
    Last Post: 12-01-2010, 11:32 PM
  5. For Sale - 2002 BMW X5 4.6is FL Car
    By domsgarage in forum BMW Cars For Sale / Wanted
    Last Post: 08-17-2006, 11:44 PM
