BAVToys
Results 1 to 3 of 3
Thread: PLEASE HELP E46 bi-xenon/halogen headaches
    Oct 2018
    Clementon nj
    1999 328i
    vehicle in question: 2002 BMW 330XI
    So i picked up the car for $1,100 it currently had bi-xenon headlights installed,and as i began to make my repair checklist to prep the car for resale i noticed the low beams were non functional,and the high beams only functioned during flash to pass(pulling on stalk)
    so to answer some of the questions that are sure to follow
    -high beams:
    -function during flash to pass
    -if i turn on the fogs and push stalk forward the blue high beam indicator in dash lights up and the fogs shut off
    -low beams:
    -after swapping headlights with a different set of xenon headlights the low beams function
    -problems i'm realizing
    -when i pulled the the donor headlights i realized there were more plugs than my car,figured the additional harness that the donor car had was for self leveling function
    (uh nope dumb ass)
    so here's my theory:
    some not so great person may have swapped out the lcm,reason for believing this is that since the high beam indicator in dash lights up and fogs turn off when the stalk is pushed forward along with the fact that the halogens don't light up at this time,tells me the lcm programming may be correct,and the stalk is functioning correctly
    they maybe swapped out headlights as well from halogens to xenon's
    and the fact that there are only 2 wiring harness plugs at the headlights mounting locations
    i may be able to grab the correct harness and likely another lcm from the donor car the headlights came from(hopefully)
    see pics below
    20181022_214830.jpg20181022_214845.jpg20181022_214959.jpg20181022_215013.jpg20181022_215042.jpg
    Oct 2018
    Clementon nj
    1999 328i
    did me sum lernin
    as it turns out the lcm stores the vehicles vin number and when it doesnt match a little dot appears near the mileage on the instrument cluster,and sure as hell my 330xi has it
    and both my 328 and 530 do not
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Plugs that are in your hand go to AL ballast and high beam halogen bulb. I am pretty sure gray is to ballast and black into high beam. Your car will probably not have plugs for a. self leveling and b. high beam bixenon signal wires (small 3 wire connector with 2 wires populated).
    Look at your rear view mirror, there is a plastic clamshell covering the mounting leg. If it is a slim clamshell - than somebody changed out your headlight switch. If it is a larger clamshell that covers rain/light sensor - your headlight switch is original to your car. I believe (not 100% sure) that on these cars, there is odometer coding within that switch.
  1. Help (factory bi-xenon replaced with aftermarket xenon (low) and halogen (high)
    By destinycat in forum Lighting sponsored by BAVToys
    Last Post: 01-19-2010, 05:00 PM
  2. Help retrofitting e46 bi-xenon projectors into e34
    By greek318is in forum Lighting sponsored by BAVToys
    Last Post: 09-11-2008, 03:43 PM
  3. Replies: 0
    Last Post: 04-27-2003, 09:47 PM
  4. Replies: 0
    Last Post: 03-24-2003, 02:12 PM
  5. E46 bi xenon upgrade question!!!
    By SPC Makoto in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-17-2003, 12:35 AM
