Results 1 to 4 of 4
Thread: Horn won't blow
    birmingham,al
    2001 3.0 Z-3 RD'STER
    Horn won't blow
    A while back, I replaced the dashboard which required removing steering wheel. Apparently when installing it back on, I did not connect something or didn't place wheel in a particular position so horn would blow. Any ideas/suggestions? All help is appreciated. Thanks!
    Johnson City, TN
    1998 Z3 with 1.9/auto
    I suspect that if your horn will no longer blow when it used to blow, possibly every time you wanted it to blow, that you may have accidentally married your horn.
    -Marshall
    Dec 2005
    Sarasota, FL
    98 M Roadster
    If you don't have an SRS light, you probably didn't damage the slip ring connections on the "upstream" side. The horn switch is part of the airbag assembly. You could pull your airbag and check the switch for continuity and/or jumper out the harness to see if you can activate the horn it without the horn switch.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by MORRIE View Post
    A while back, I replaced the dashboard which required removing steering wheel. Apparently when installing it back on, I did not connect something or didn't place wheel in a particular position so horn would blow...
    A DIY on that, which you probably don't need since you already know how to get in there.
    http://forums.bimmerforums.com/forum...rn-not-working
    BMW MOA 696, BMW CCA 1405
  1. Horn won't stop blowing. Anybody know how to fix it?
    By BimmerM3inGA in forum 1992 - 1999 M3 (E36)
    Last Post: 04-13-2008, 06:39 PM
  2. Horn won't work...Help please!
    By MostWanted in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-22-2006, 10:53 AM
  3. Horn won't work......HELP!!
    By Flexia in forum 1992 - 1999 M3 (E36)
    Last Post: 11-17-2005, 09:26 PM
  4. Horn won't work -- not fuse
    By sundownz in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-04-2005, 08:52 PM
  5. Heater won't blow hot when cold outside, but will when its hot?
    By schwarzIIe36 in forum 1991 - 1999 (E36)
    Last Post: 12-25-2004, 03:57 PM
