Results 1 to 4 of 4
Thread: Stuck caliper causing abs and tsc light?
    Nov 2017
    Canada
    1998 E36 328i
    How likley is it that my abs and traction control light on due to a stuck caliper?
    Jun 2010
    NY
    1997 328i
    Usually dirty abs sensors.
    Dec 2014
    Alexandria, Va
    1996 328is, 2003 325ci
    Do you have a stuck caliper or just fishing for clues?
    Nov 2017
    Canada
    1998 E36 328i
    I do have a stuck caliper, with a new one on order but i did clean and replace the front abs sensors, the rear are both quite stuck so ill have to work on that.
  1. Turning on Cruise Control caused ABS, DTC, and Orange Brake Warning light.
    By rainmaker92 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-01-2020, 02:51 AM
  2. Brakes Stuck On!!!! (DSC, ABS, Brake Lights On)
    By 328ci906 in forum 1999 - 2006 (E46)
    Last Post: 01-17-2012, 08:32 PM
  3. Snow or slipping causing abs/brake/traction control light?
    By 330CIAF in forum 1999 - 2006 (E46)
    Last Post: 12-25-2009, 12:02 PM
  4. ASC Light Stuck On - Need ABS-DSC Control unit
    By 94silverbullet in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-13-2007, 10:15 PM
  5. ASC Light Stuck On - Need ABS-DSC Control unit
    By 94silverbullet in forum 1996 - 2003 (E39)
    Last Post: 04-12-2007, 11:20 PM
