Results 1 to 5 of 5
Thread: Gas cap hissing
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    Gas cap hissing
    There has always been a fair amount of hissing when my coupe’s gas cap is removed. Just changed the fuel pump with an oe BMW unit and the hiss is completely gone. What changed?
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    As changing the pump should have no affect on tank vacuum - I would guess that the rubber ring has not been installed correctly:
    http://www.realoem.com/bmw/enUS/show...22#16111179637
    My BMW Repair YouTube Channel
    San Francisco, CA
    So what is the norm, a certain amount of vacuum hissing or none at all? As for the rubber seal installation, I made sure the seal was seated properly, then the plastic lock collar was tightened to spec.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    San Francisco, CA
    The swoosh is back. Tightened the lock collar a little more, guess it was not torqued adequately. Used another better quality torque wrench and tightened to 41 lbs.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    are the fuel tank breather valves connected? Check the hoses from throttle valves to charcoal filter, especially the plastic distribution piece #14, that often breaks, http://www.realoem.com/bmw/enUS/show...diagId=13_0354
    If the valve is working properly, it is sprung closed and powered open. quick test of fuel tank breather valve: The fuel tank breather valve should have a resistance of 45 ohms ± 20 and be closed in de-energized state.
  1. Is there such thing as a locking gas cap for our cars?
    By Kudo540 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-22-2004, 06:10 PM
  2. Gas cap boneheadism...
    By Bernman in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-23-2003, 04:46 PM
  3. Aluminum Race Gas Cap...
    By Symptom in forum 1992 - 1999 M3 (E36)
    Last Post: 08-06-2002, 02:39 PM
  4. gas cap actuator
    By umnitza in forum 1992 - 1999 M3 (E36)
    Last Post: 11-11-2001, 09:55 PM
  5. gas cap problem, WTF! hELP!
    By vdo in forum 1992 - 1999 M3 (E36)
    Last Post: 08-11-2001, 06:11 PM
