Page 3 of 3 FirstFirst 123
Results 51 to 60 of 60
Thread: Car pulls right, even worse when braking
  1. #51
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by jmile46 View Post
    I did not think of that! And part numbers are different! Attachment 640173
    Original is 60/28/302
    Reman is 60/22/302
    Attachment 640174
    So what is this telling me?
    Edit: I now see that my calipers are in fact 540i! Welp that explains my issue here. Thats pretty cool though! Lol. But in terms of the new pads I bought, will those not fit now?! Or do pads remain the same?
    Pads are same for 525 & 540. The difference is the thickness of the rotors, 22mm. (525, 530, 535) v 28 mm. (540) A thicker rotor with better heat dissipation for heavier 540. Worth noting that the ~ just as heavy 530(V-8) has the smaller brakes
    The #s on the caliper casting indicate bore size, 60mm / rotor thickness, 22 or 28 / rotor diameter, 302mm
    I wondered what the hell you meant when saying the ones you got were too small.
    As long as the mounting bracket and rotors are appropriate you can switch one size for the other. There is no benefit to this aside better resistance to fading with repeated stops. Braking performance is same, the 540 brakes will just take longer to overheat with repeated hard use.
  2. #52
    Dec 2017
    Chicago Illinois
    2003.5 E46 M3, 1992 e34
    Quote Originally Posted by ross1 View Post
    Ah good to know! Yup I double checked about the pads. I picked up the caliper last night so finally I can wrap up this job!
  3. #53
    Dec 2017
    Chicago Illinois
    Well brakes are all finished up. To my disappointment, the car is still pulling right. I lifted the fronts and both sides spin about the same.( which isn’t much). Given I still need an alignment. Im kind of at a loss here. Im going to flip flop wheels tomorrow.
  4. #54
    NW suburban Chicago
    hiss by my window
    This seems to be the elephant in the room. Braking changes the suspension geometry, properly aligned it won't steer the car, if way out it can.
    Everything is bled correctly? You are welcome to come over and use my power bleeder if you suspect not.
  5. #55
    Dec 2017
    Chicago Illinois
    I mean I replaced the tie rods and center drag link and adjusted the tie rods by eye so Im sure they are pretty far off. But despite changing everything the pull to right still has the same force it did at the beginning, if that makes sense. It didn’t decrease or anything.
    Im pretty sure they are bled properly! Thank you for the offer, Ill keep it in mind though.
    As of now, one thing that came to mind is I replaced my left front wheel bearing/ hub a couple months ago. But Im not sure that would cause such an imbalance.
  6. #56
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Does it pull without braking? Rotated tires?
  7. #57
    Dec 2017
    Chicago Illinois
    Quote Originally Posted by moroza View Post
    Yes it pulls without touching brakes. I take back my initial title name, under braking it remains the same. Braking does not make it worse. And Im pretty busy this week. Won’t get the chance to rotate tires till the weekend. IMG_0523.jpg
    I noticed my right caliper looks like this. Notice on left side the darker tint to it. I bedded the new pads. Im not sure what this means.
  8. #58
    Dec 2017
    Chicago Illinois
    Ughh, stupid me chasing problems when the simplest diagnosis, which I was told to do early on, ended up being the culprit. I swapped my front tires and what do ya know, car pulled left. Took wheel back off and noticed that when sitting it up and rolling it was extremely tilted towards face of wheels. Almost like it needs 3 pounds of weights on the inner part of barrel. Im not sure what the hell is wrong with it but as a temporary fix I threw it onto the back and voila, no more pulling. For needing an alignment the car drives pretty damn straight! I have new wheels im putting on in coming weeks so Im not worried about it.
  9. #59
    moroza's Avatar
    BFE
    E34T
    Sometimes it's only after years of stupid tail-chasing (not that kind...) that a mechanic - this one, anyway - gets good at implementing Occam's Razor. Live and learn. Glad you found the problem.
    What I'm picturing as you describe that wheel is something I would not mount anywhere on the car. If you drive on it at all, be slow and extra-careful with that wobbly WTF on.
  10. #60
    Dec 2017
    Chicago Illinois
    What I'm picturing as you describe that wheel is something I would not mount anywhere on the car. Drive slow and extra-careful with that wobbly WTF on.
    LOL! Yeah now I know. I truly don’t understand whats up with it. Very face heavy. Tires are kind of old so who knows. They will be off in a week or so anyway.
  1. After new wheels and tires car pulls right
    By berkshire in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-21-2009, 08:25 PM
  2. Car pulls to the left when braking
    By cdc84 in forum 1988 - 1996 (E34)
    Last Post: 09-27-2009, 12:15 AM
  3. car pulls to the left under braking
    By todor in forum 1975 - 1983 (E21)
    Last Post: 11-16-2007, 11:05 PM
  4. My car pulls to the left while braking
    By Daved in forum 1991 - 1999 (E36)
    Last Post: 07-28-2005, 12:53 PM
  5. Car pulls side to side when braking...
    By Armo95 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-29-2003, 01:43 PM
