Results 1 to 25 of 60
Thread: Car pulls right, even worse when braking
    Dec 2017
    Chicago Illinois
    2003.5 E46 M3, 1992 e34
    Hey all, so my e34 has been having an issue where it pulls to the right when driving, i have to hold wheel to the left for it to go straight. And if i put wheel straight it pulls right very hard. When I brake this is amplified even more. I just installed brand new tie rods, steering drag link, and idler arm and car feels more solid but still pulls same way. I know I need an alignment but even after adjusting tie rods by eye(lol) I find it hard to believe car will pull in the same manner as before. What I’m trying to figure out is if its simply my thrust arms are shot or if I have a sticking caliper. Any thoughts guys?
    Also if I get an alignment before replacing thrust arms, will I have to get another one after?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Quote Originally Posted by jmile46 View Post
    EDIT: the textbook answer is yes. The real-world answer is that if you're replacing quality parts with same, and they are worn to the point of causing a shimmy (the usual reason for replacement) but not actually loose or deformed, you can *typically* get away with not resetting the toe afterwards. YMMV.
    Lift up the front, check wheels for dragging, and swap them side to side (if they're directional, then swap them back after a testdrive).
    Dec 2017
    Chicago Illinois
    Quote Originally Posted by moroza View Post
    Yes.
    By swapping them side to side, thats to identify if its a wheel issue causing this?
    Sep 2001
    Sharon CT
    You've eliminated the possibility of it being a stuck brake caliper or stuck brake pads on the right side correct ?
    Herr, wirf Hirn vom Himmel! ... oder Steine, Hauptsache er trifft.
    88 Alpineweiss / black E30 M3 -Project.
    Brilliantrot / black US SPEC 3/90 prod e34 M30b35 535i 5spd - Modded.
    98.5 Tiag Silber /black e36 m3 - Modded.
    99.5 Estoril Blau /dove e36 m3 - Modded.
    07 Crimsonrot /black E83 X3 6spd - Stock..
    Dec 2004
    CT, USA
    e28, e34, e39
    String alignment is free and accurate.
    demet
    Dec 2017
    Chicago Illinois
    Quote Originally Posted by Neel View Post
    I have not. How do I do this? Just lift front and spin wheels by hand?
    Wisconsin
    '95 525it
    You could drive the car around the block and see if one wheel is getting warmer than the others.
    NW suburban Chicago
    hiss by my window
    worn control arm bushings can cause this
    Dec 2017
    Chicago Illinois
    Thanks for the input guys. Ill do some testing for a sticky brake, but either way at 252k shes overdue for some love. Just ordered new thrust arms, pitman arms, subframe mounts and diff mounts. All steering components are new. Lower control arms looks fine as do sway bar bushings. So this weekend Ill give ole girl a refresh, hit the road and see how it feels. Then alignment next week.
    moroza's Avatar
    BFE
    E34T
    Yes. But first...
    ...do exactly that.
    Quote Originally Posted by demetk View Post
    And determines only toe, which doesn't cause pulling.
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    This thread should be helpful to you :
    https://www.bimmerforums.com/forum/s...Push-Out-Right
    … but you will likely have to rebuild your right calliper entirely. This op had an obscure problem and the solution was equally obscure, but did not require rebuilding, which is usually not the case.
    Dec 2017
    Chicago Illinois
    Quote Originally Posted by alang1990 View Post
    If none of these other things help me, thats the path!
    Dec 2017
    Chicago Illinois
    Well, i finally had time to actually lift up the car today and upon spinning front wheels un the air, or should I say attempt to spin them! Looks like my right caliper is totally sticking. Can hardly even rotate the damn wheel by hand left side is not nearly as bad, but still doesn’t seem perfect considering a brand new wheel bearing. So looks like both calipers are in need of changing.
    So what are my best options?
    Buy new calipers or rebuild?
    Also considering the right pads have been constantly rubbing will I need to change pads and rotors? Besides this issue both have plenty life.
    Lake Elsinore CA
    1991 BMW 525i
    Before you go buying calipers, take the right one off, check the slide pins for corrosion and grease as necessary, and push the piston back in until it seats. Your piston might just be sticking along with the guide pins. When's the last time you changed your brake fluid also? Old nasty fluid is not conducive to a well functioning brake system.
    Chris
    1991 BMW 525i
    M50 with auto trans
    Build date 10/90
    Alpine White II
    Black/tan interior with leather
    Dec 2017
    Chicago Illinois
    Quote Originally Posted by trackerrrr View Post
    Ahh good idea! Next time I get the chance, Ill definitely check that before spending ghe cash! But ive owned car for just about a year so brake fluid is unknown. Id imagine its old.
    Lake Elsinore CA
    1991 BMW 525i
    Rebuilt calipers are not that expensive if you go that route. Just remember the brakes are the most important system on your car, get as good stuff as you can.
    Chris
    1991 BMW 525i
    M50 with auto trans
    Build date 10/90
    Alpine White II
    moroza's Avatar
    BFE
    E34T
    I've had a ~50% success rate rebuilding hydraulic cylinders at home. If you have lots more time than money, and can afford downtime, buy a rebuild kit and try your luck. Otherwise get good used (I have a pair assuming it's not a 540i or M5) or a quality reman, t.i not Cardone.
    There's going to be a little brake drag even with healthy calipers. If you can get at least one or two full free-spinning rotations, I'd leave that side alone.
    If there's no shimmy while braking and the rotors don't have grooves, big lips, or other damage, leave them and the pads alone too.
    the brakes are the second most important system on your car after steering
    FTFY
    Dec 2017
    Chicago Illinois
    FTFY
    Its a 525i. After looking into it id probably prefer to just spend the money on rebuilt. Drivers side definitely gets a couple rotations so it is probably fine. I do get brake shimmy when braking from higher speeds unfortunately. No noticeable flaws in rotors, possibly warped? Id prefer to leave all else alone. Is there a sure way to tell if the rotors are warped?
    Dec 2017
    Chicago Illinois
    Whats a good brand of rebuilt calipers? I see some on ecs tuning.
    moroza's Avatar
    BFE
    E34T
    Measure runout with a dial indicator:
    Which will cost at least as much as the ~$30 for having both front rotors machined at just about any auto parts store.
    Dec 2017
    Chicago Illinois
    Yeah I think I’ll just get them cut lol
    Dec 2017
    Chicago Illinois
    I took off the caliper today and checked my slide pins, nothing abnormal. I relubed them and compressed the piston and put everything back on. Spun wheel and it spun freely! But after first drive, no surprise same issue, and i spun the wheel and it was seized again. So it appears to me that the caliper won’t disengage after engaging, so does this mean Im looking at needing a new caliper?
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    You probably need new caliper seals. The old ones have lost their flexibility and not allowing the pistons to move freely when brake pressure is withdrawn.
    Since you already know how to take out and reinstall the calipers, why don't you rebuilt them yourself ? Unless you get a pair of rebuilt callipers cheap.
    It is really unusual for caliper pistons to be damaged. But if you suspect yours actually are, or don't want to take the risk, then get rebuilt callipers.
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Actually OP, I have a hunch. Want to give it a try ? Open the bleeder nipple for the offending calliper and squeeze the piston. Brake fluid will come out, and possibly solidified dirt right behind the piston. Solidified dirt near the brake line may also venture out - perhaps that's whats causing the problem.
    A bit of a long shot but hey. Anyway, that is the correct way to bleed brakes - the callipers need to be depressed a few times to get the mud out.
    Make sure you are topping up the reservoir constantly when you do this do not let air get sucked into the reservoir.
    Dec 2017
    Chicago Illinois
    I dont suspect the piston is damaged. I have no idea if it is or not. Im not sure what goes into replacing the caliper seals. Is there a diy? Id possibly give it a shot but if its super involved or tedious Id probably rather just bite the bullet on a rebuilt one for $90 on ecs. Would i need to do both sides? Or can I just fix or replace the one giving me issues? Same for pads and rotors? If I fix caliper, can I just cut rotors and leave pads?
  1. After new wheels and tires car pulls right
    By berkshire in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-21-2009, 08:25 PM
  2. Car pulls to the left when braking
    By cdc84 in forum 1988 - 1996 (E34)
    Last Post: 09-27-2009, 12:15 AM
  3. car pulls to the left under braking
    By todor in forum 1975 - 1983 (E21)
    Last Post: 11-16-2007, 11:05 PM
  4. My car pulls to the left while braking
    By Daved in forum 1991 - 1999 (E36)
    Last Post: 07-28-2005, 12:53 PM
  5. Car pulls side to side when braking...
    By Armo95 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-29-2003, 01:43 PM
