Results 1 to 22 of 22
Thread: E36 Interior Parts
    Oct 2013
    Portland, OR
    328i,740i,e36 m3 x2,e46
    E36 Interior Parts
    Will add to the list as I continue to inventory everything I have but here is a start. Prices are plus shipping. PM will get fastest reply, if you have any questions send me a message. I have multiples of most items. Thanks!
    RH Vert/Coupe Dove door panel $150
    LH Coupe/Vert dove door panel $150
    LH dove rear panel $30
    RH dove rear panel $30
    RH tan rear panel $30
    LH tan rear panel $30
    LH tan rear sedan door panel $30
    LH dove rear sedan door panel $30
    RH Tan rear sedan door panel $30
    RH black rear sedan door panel $30
    RH grey sedan panel $30
    RH black sedan panel $30
    RH tan sedan panel $30
    8 tan front headrests $20
    2 magma front headrests $30
    Storing partitions $60 each
    Tan storing partition w/sedan surround(central lock)
    Black storing partition w/ sedan surround(central lock)
    Black storing partition w /vert shift surround(central lock)
    Sedan shift surround $35
    Kick panels $20 each
    Black LH coupe kick panel
    Gray RH coupe kick panel
    Tan RH coupe kick panel
    Tan sedan RH kick panel
    Black sedan RH kick panel
    Gray sedan RH kick panel
    Tan coupe dash $50
    Black sedan dash no airbag $50
    Black sedan dash $50
    Magma sedan carpet $130
    Tan coupe rear carpet $25
    Behind rear seat trim coupe $15
    Vert top header panel $25
    Door sill plate $15
    Tool box w/o tools $10
    Battery cover tray vert $15
    Battery cover tray $15
    Battery cover tray w/ lug wrench $30
    Battery cable cover (trunk) $10
    Trunk carpet support piece RH $15
    Trunk carpet support piece LH $15
    LH coupe w/tilt under wheel trim black $50
    RH under dash panel $25
    RH under dash panel w/hole for light $25
    Vert ski bag $40
    All tail covers $12 each
    LH vert taillight trim
    RH vert taillight trim
    LH coupe taillight trim
    RH coupe taillight trim
    LH sedan taillight trim
    RH sedan taillight trim
    Sunglass cubby $12
    Grey glovebox vent $25
    Tan glove box vent $25
    Black glovebox vent $25
    Black no airbag glove box vent $25
    Tan vent panel trim strip $12
    Module holder early $12
    Module holder late $12
    Seatbelt sliders $8
    Rear center belt receiver $10
    Rear center belt $8
    Vert rear seat belt $15
    Coupe LH belt $25
    Coupe RH belt $25
    Sedan LH front belt $25
    Sedan RH front belt $25
    Vert LH front $25
    Sedan rear $15
    Coupe front belt receiver LH $25
    Coupe front belt receiver RH $25
    RH rear vert belt receiver $10
    LH rear vert belt receiver $10
    Sedan lh rear receiver $10
    Sedan RH rear receiver $10
    Coupe LH rear receiver $10
    Coupe RH rear receiver $10
    Airbag colored emblem $25
    Airbag embossed emblem $25
    Rear view mirror $15
    Rear view mirror skinny type $15
    Gas pedal $20
    Vert rear defroster $20
    Steering column trim $20
    Parking brake boot $20
    Parking brakes handle/lever $15
    Parking brake handle/lever wood trim w/ boot $30
    Control stalks $12/each
    Turn signal stalk
    Turn signal stalk w/ BC
    Wiper stalk
    Cruise control stalk
    Inside handles $12/each
    Coupe RH inside door handle
    Coupe LH inside door handle
    Sedan front LH Inside door handle
    Sedan front RH inside handle
    Sedan rear LH inside handle
    Sedan rh rear inside handle
    Trunk carpet/floor piece $20
    Vert trunk lining(3 piece) $40
    Sedan trunk lining(3 piece) $40
    LH trunk lining $20
    RH trunk lining $20
    Tan Armrest console $60
    Black incomplete console $40
    Tan incomplete console $40
    Black incomplete sedan console $40
    Gray coupe c pillar RH x2 $25
    Gray coupe c pillar LH x2 $25
    Tan sedan a pillar RH $25
    Tan sedan a pillar LH $25
    Tan coupe a pillar LH $25
    Black vert a pillar pair $65
    Black coupe a pillar RH $35
    Tan sedan coin tray door panel $20
    Gray sedan coin tray door panel $20
    Tan coupe coin tray $20
    Black coupe coin tray $25
    Gray coupe coin tray $20
    Tan sedan sunroof motor cover $20
    Gray sedan sunroof motor cover $20
    Gray coupe sunroof motor cover $20
    Vert sunvisors pair $20
    Tan sunvisor RH $10
    Tan sunvisors LH $10
    Gray sunvisors RH $10
    Gray sunvisors LH $10
    Vent window hinge RH $8
    Vent window hinge LH $8
    Sent from my SM-N920V using Tapatalk
    May 2015
    NEW YORK CITY
    1998 BMW 328
    txt 646 712 6106
    looking for a rear parcel w/3rd braklight
    May 2015
    U S A
    yay
    I need two black M3 c-pillar lights.
    Oct 2013
    Portland, OR
    Quote Originally Posted by beemerdreemer24 View Post
    txt 646 712 6106
    I have a couple sedan pieces here, just got rid of last coupe one. Well actually there could be some under my house. I'll check
    Oct 2013
    Portland, OR
    Quote Originally Posted by xxxxxxx View Post
    Sorry, don't have any black lights here at all. Thanks
    TR
    e36 m3
    do you have m3 gauge
    Jul 2018
    BC
    1998 M
    Could you please pm me pics of magma headrests, Thanks
    Orlando, FL
    1997 M3
    I’ll take the LH window hinge if you still have it. PM sent.
    Jun 2008
    Trenton, NJ
    1997 M3 Coupe, 1999 Ram Air Trans Am
    any M3 coupe door panels in black? e36
    1997 Hellrot M3 Lux
    gone but not forgotten!
    2008 535i black sapphire metallic
    Dec 2002
    Broward, FL
    I take the bus to work.
    any black e36 armrests?
    -M3J0N
    Sep 2004
    Texas
    E36 318iC 6mt vert
    I'd be interested in a passenger side A pillar cover if you still have one and if it will fit a vert.
    NY
    skateboard
    I'm interested in the center vent, center console, and shifter surround all in black.
    ― George Orwell
    Aug 2019
    Bay area CA
    e36 m3 coupe
    Do you have black C pillars? thx
    Feb 2004
    san antonio t.x.
    97 m3 lux,
    Black sedan lower b pillar passenger side?
    97 BYZANZ M3 LUX
    Aug 2019
    Mountain Home, Idaho
    1996 BMW Z3
    I'm looking a storage compartment lid that sits back between the seats on my 1996 Z# roadster. Black.
    Idahored
    Mtn Home, Idaho
    1996 BMW Z3 Roadster
    convertible
    NY
    skateboard
    Pm’d
    ― George Orwell
    Tampa, FL USA
    1995 E36 M50 soon to
    Do you still have the B Pilar's? Also looking for all interior lights in black.
    Apr 2022
    Fort Myers FL
    96 BMW 328i/332i sedan
    WTB dove grey sedan rear seat. please let me know. my handle is new only because i could not find my original sign on so had to make a new one. im in fort myers fl. thanks jay.
    Aug 2019
    Socal
    E30
    Dark grey a-pillar for sedan?
    Oct 2003
    Ottawa
    1995 BMW 325i
    Do you have any tan sunroof items left?
    Current Cars:
    1995 BMW 325i
    2013 BMW X3
    2017 Infiniti QX30
    Past Cars:
    1997 BMW M3
    2011 Chevrolet Avalanche LTZ
    2010 GMC Terrain
    1998 BMW 328is
    2006 BMW 325i
    2007 Saab 9-3ss AERO
    2004 Saab 9-3ss Linear
    2003 PT Cruiser
    2001 Volvo S40
    1990 Honda Accord EX-R
    California
    Bmw 328i, Mitsubishi Eclipse 3g
    black b pillar sedan in good condition?
    pull handles for sedan in black
    sunvisors in black sedan
    interior lights in black?
    Do you still have any of these?
    Jul 2022
    Palm Harbor, FL
    1997 328i Convertible
    i would like to know what you'd take for a center dash vent, as I didn't see them in the list.
  1. E36 Many E36 Interior Parts (Black)
    By jason325is in forum Interior Lighting & Body Parts
    Last Post: 03-04-2011, 03:07 PM
  2. E36 E36 Interior Parts!!!
    By Em1 For Life in forum Interior Lighting & Body Parts
    Last Post: 09-28-2010, 01:53 PM
  3. E36 FS - Lots of E36 Interior Parts and Seats.
    By Nemesis519 in forum Interior Lighting & Body Parts
    Last Post: 08-23-2010, 03:01 AM
  4. E36 Various Black E36 Interior Parts
    By WCM3 in forum BMW Parts Wanted
    Last Post: 05-18-2010, 12:22 AM
  5. E36 Lots of e36 Interior Parts LOOK
    By slide2side36 in forum Interior Lighting & Body Parts
    Last Post: 04-27-2010, 09:33 AM
