BAVToys
Results 1 to 4 of 4
Thread: Halo Replacement
    May 2018
    Seattle
    1997 Z3
    Halo Replacement
    I have a 1997 BMW Z3 that has one headlamp bulb out and both angel halos. How straight forward is replacing the halos and do they need to BMW certified or something to not get the error message I'm reading about. Recommendations on where to get them also appreciated.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Your Z3 did not came with angel eyes so somebody a. Added rings only to your otherwise stock headlight housings or b. Replaced entire housings with aftermarket units. Depending on which option took place in your Z3, the replacement will be different. Add on rings - you cannot replace the "bulb", you need to replace entire ring. In aftermarket housings - depends on how they are built, but in most cases you are looking at replacing entire ring as well. As a first step, I would make sure that the side that doesn't work has 12V going to it.
    May 2018
    Seattle
    1997 Z3
    The side has power, at least as I understand it, there is power to the high beam, it is only the low beam and the halo rings that are not working. There doesn't seem to be a clear way to get access to the halo rings, nothing through the back and the lens does not appear to come off easily.
    Jun 2017
    Los Angeles, CA
    BMW M3
    ive seen some aftermarket halo rings that can added. have you considered going that route?
  1. Halo replacement globes
    By bimas in forum 2004-2010 (E60,E61)
    Last Post: 12-01-2015, 03:33 PM
  2. 2006 halo replacement issue
    By reidgraulich in forum 2004-2010 (E60,E61)
    Last Post: 01-03-2015, 01:45 AM
  3. e90 LED halo replacement in NorCal
    By francis335i in forum California sponsored by Avus Autosport
    Last Post: 07-03-2014, 12:17 PM
  4. Dead halos - replacement part name?
    By Brashland in forum Lighting sponsored by BAVToys
    Last Post: 09-04-2012, 11:27 AM
  5. 2006 330i Halo replacement
    By zuti in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-23-2011, 12:41 AM
