Looking to sell my e36 M3 Coupe with @ 185k on it which I was building towards an IS class race car, however I have kept it as a street legal track car once I started having kids only making it to 3 events and a couple autocrosses. With 3 kids now I don't have enough time for the racing hobby so I am moving on from this project.
I bought the car in 2009 from a friend and fellow BMW CCA member who owned it since @2002 and I believe I have full records documentation for the history of the car in my folder. I did a bunch of mods and maintenance work to prep the car for track duty but because I drove it to and from the track I left the AC and stereo partially in (the speakers can be removed once at the track). The car has valid NJ inspection until late 2018 and passes inspection just fine each time.
Brakes
BimmerWorld Steel Braided Brake Lines
UUC stock replacement rotors front and rear
PerformanceFriction PFC01 Brake Pads
Removed parking brake cables
Drivetrain
UUC DTM Exhaust
UUC Lightweight Flywheel & Clutch combo
Diff upgrade with Rogue Engineering Finned Diff Cover and tapped front mounting to accept m14 bolt from an x5 instead of the m12 from the e36 M3 which frequently breaks
New BMW alternator
New pulleys & tensioner
New Serpentine belt & AC Belt
New valve cover gasket
New NGK plugs
New air filter
Aluminum thermostat cover
New oil filter
New fuel filter
Lightweight Deka battery
Mishimoto Aluminum Radiator
Stewart Water Pump
Zionsville shroud + Spal fan
Rebuilt half shafts with new boots and Redline Racing CV grease
New Guibo
New Center Support Bearing
New Rear Wheel Bearings
New Rear Hubs
Fluids
OEM Oil
Redline Tranny Fluid
Redline Diff fluid
Motul RBF600 brake fluid
OEM Coolant 50/50 with distilled
Suspension
Ground Control Coilovers with Koni shocks/struts and 440lb front and 550lb rear springs
UUC Sway Bars
UUC Rear Subframe Bushings
UUC RTABs
UUC Red Tranny Mounts
Eibach Adjustable Rear Control Arms
BMW Diff Bushings x3
BMW Ball Joints x6
Exhaust hangers x4
BMW e90 M3 Engine Mounts
BimmerWorld Solid LCABs
1995 M3 Control Arms
swapped my 98 strut mounts for more negative camber
Rebuilt GC RSMs
Chassis - Reinforcements
Bull Dog Motorsports custom made welded in rollbar that is the back half of a BMW CCA Club Racing rules conforming roll cage (incase I or the next owner ever go racing it will just require the front half to be completed)
Turner Motorsport Rear Sway Bar Reinforcements - Welded
BimmerWorld Trailing Arm Reinforcement - Welded
BimmerWorld Front SubFrame Reinforcement - Welded
BMW e36 M3 LTW X-Brace
Drilled Front Diff Bushing and Tapped Diff to accept M14 bolt instead of M12
Steering
PS Pump
PS Reservoir
PS hoses x 3
Rebuilt steering rack from rackdoctor.net
Lemfoerder Inner & Outer Tie Rod Ends
Wheels & Tires
BimmerWorld Wheel Studs
17" ASA AS1s on car as street & rain setup
17" Kosei K1s with 245 Kumho v710s as track wheels / tires (tires are old now and need to be replaced)
ARD 10mm wheel spacers up front
Interior
Kirky Race Seat
Sparco Race Seat
VAC Seat Mounts
Schroth 6 Point Harnesses
BimmerWorld Aluminum Door Panels
Momo Steering Wheel Hub
Rogue Engineering Quick Release
Momo 330mm Steering Wheel
I/O Port Camera Mount
stripped interior & trunk
removed sound deadening & tar crap
removed airbags
Exterior
Stealth underpanel
SRT fiberglass sunroof panel
Not installed but included with sale:
Mason Rear Strut Bar
BimmerWorld Brake Cooling backing plates
Hard Motorsport Brake Cooling ductwork (allows for easy removal of front bumper without undoing the brake ducting)
New Lemfoerder strut mounts
Powdercoated Rear Bulkhead Panel
3 VDO Gauges + e36 3 Gauge Panel where OBC goes
Thule Roof rack
Rebuilt DS window motor
Original diff
4 brake calipers (2F & 2R)
1998 style front control arms (need new ball joints pressed in, would throw off castor due to the treehouse racing style CABs?)
original rear hubs
extra stock diff cover
stock engine mounts (in good shape)
stock roof panel & all mechanisms including metal sunroof panel
2 sets of rear M3 Coupe seats in black
Various interior pieces including sunroof motor
Car cover
Only known issues:
- power windows have issues going up and/or down unless hardwiring to battery/power source (prob not an issue for Scott who would trailer the car)
https://www.youtube.com/watch?v=Kf21nMh_oos
- some scratches on the paintwork
- passenger side front fender had been repainted from fire damage from a car parked next to it when the PO still owned the car
Asking price is $9,750 OBO and the car is located in Central NJ near where 287 and 78 and 22 all meet
Pics:
Any interest in a trade
https://longisland.craigslist.org/ct...729611669.html
I'm an Aussie living in the States , love it
Modestly dyslexic so for give the spelling.
